Nikon D70S Digital Camera with AF 28-80mm f/3.3-5.6G Lens Logo
Anonymous Posted on Aug 04, 2012
There is a line appearing from the center of the view finder till the end. This comes on only when the camera is switched on
When I switch on the camera there is a small line runing from the central focus point till the end of the view finder. I have the view finder grid display on. The grid lines are thicker. This line i am talking about is a very thin line. If I switch off the camera and look into the view finder the line does not exist. It comes on only when I switch the camera. Please advise. I can be reached at [email protected]
  • Anonymous Aug 05, 2012
    Rajdeeep, I get the line only whne I power on the camera. THe nikon manual says its expected behaviour. The pohtos come clean, without any lines. In fact the hpotos are crytal clear, so thats why the line has got me worried a bit
    Rajesh dont worry. This is common. Actually its happens because of electrical frequescy its not gonna damage your LCD screen. I just suggest you don't you power supply for the camera so long. Its over heat the ciucuit board and for that reason you may lost the LCD or roated s=circuit panel. But this line and trickling its a common with each annd every camera. Some are more visible and some not too .
Anonymous
Level 3:
  • Master 2,517 Answers
  • Posted on Aug 05, 2012
Anonymous
Master
Level 3:
Answers
2517
Questions
Helped
483667
Points
8373
If the line came in photos when you seen them from PC then its a Camera CCD fault, Or If the photo clear in PC view then its a LCD fault.
5 Related Answers
zohail
Shoaib Rais
  • 1223 Answers
  • Posted on Feb 25, 2009
SOURCE: i can't see any thing through the view finder or display on a nik
could u take pics are they ok on pc or they are also blank black pics if thats the case then my friend it seems like ur CCD has stopped working , there is strong chance of that , does it have any CR type battery to be replaced pls check some cameras do have those batt otherwise check its CCD from service center i am pretty sure abt that
Anonymous
  • 2985 Answers
  • Posted on May 18, 2007
SOURCE: black and white lines in view finder
Screen or main board failure. If it is still under warranty you may have a chance bit if over a year or so old - not worth considering for repair- though you could try. take a look through the file here http://www.fixya.com/support/p423-nikon_coolpix_5600_digital_camera/solutions
Anonymous
  • 2985 Answers
  • Posted on Aug 30, 2007
SOURCE: Verticle Lines
This is a CCD or main processor failure. Nikon will advise repair or replace.
HyeProfile
HyeProfile
  • 35 Answers
  • Posted on Jul 10, 2009
SOURCE: Nikon D60 use of Display to take pictures rather than view finder
The Nikon D60 does not have "live view" capability, so you'll need to use the viewfinder to frame you shots. If you need "live view" capability, consider purchasing the D80 or D90 instead with offer the feature...
Anonymous
  • 11967 Answers
  • Posted on Mar 22, 2010
SOURCE: My camera turns on, but will not focus. You can
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
2answers
Cant see through my view finder on powershot s3 is
Your camera has an electronic view finder. To switch between the view finder and the display, you have to press the DISP. button several times and look what happens in Shooting mode and what in Playback mode. If only the display will come on, and the viewfinder stays black the camera will have a defect. If you can't use the camera anymore, because you only can shoot with the viewfinder, consider buying a new camera, because any repair will be more expensive than a new camera with the same quality.
Off lens,view finder is not workink
The view finder is the little window on the top left of the camera. If you want to use the display as a view finder, you have to press the button with the camera logo. It is called the life view mode. you use the same button to switch off the display. Be aware using the display, will drain the batteries quicker. Somewhat faster then with modern cameras.
see page 19 of the manual.
This camcorder hasn't been used for many years but when I switch it on although it has power to it, the view finder just has a vertical white line down it. It's the same whether it's on 'camera' or...
Does it work at all with out the view finder? If it does work completely then you can use the camera without the view finder. Point and shoot and the more you use it the better you get at it. Good Luck
Jan 06, 2011 • Cameras
My Sony Hc42 camera LCD, view finder gone blank
cheak ur lcd srip and there is a samll switch that chaing over switch cheak it
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
The lens on my Sony W130 goes in and out.
I will forward a link to a page where you can get more information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C91134
If the issue still persists then service of the Camera is recommended.
I can't see any thing through the view finder or display on a nik
Finder focus problem
is there a little slider type bar/switch/button on the finder, most cameras have them to compensate for different peoples eyesight. if there is, look through it, put camera in auto focus and when its focused, look through finder and move bar/switch... til pic is clear
I have a Samsung VP-D20 The camcorder switches on ok, all the information appears in the view finder or on the LCD but there is no recording image on the screen or in the view finder, the recording light...
Yes I have solved the problem with this camcorder. I had a scrap unit which had a liguid spillage. Thanks to your help I stripped both units down and changed the lens assembly complete with the electronics, the camcorder now works fine.
I am waiting for help with a samsung D 363.
Regards James.
View finder
I had the same problem, it is the switch inside that is broken which allows you to switch back and forth between viewing pictures and taking them. There isn't really a fix besides getting the switch replaced and I am having a very hard time trying to find parts for mine. Good luck.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
