Marantz SR-5200 Receiver Logo
Question about Marantz SR-5200 Receiver
Marantz sr5200 digital input problem - system is configured correctly
The system suddenly stopped handling both the optical and coaxial digital inputs. The system otherwise works fine however when using any of the digital inputs the output to the speakers is hiss. If you unplug the optical input the hiss will stop, indicating that the system can properly detect the presence of the signal but is failing to process it correctly. Any suggestions are appreciated. Thanks, Erik
2 Related Answers
Anonymous
SOURCE: Only the main speakers are functioning...
Replace the A/D converter CS4228A on the DSP Board
Posted on Nov 24, 2007
Anonymous
  • 3600 Answers
SOURCE: Hi ,Marantz SR7200 , i am getting an audible hiss
if your hooking up a phono input lead to a digital input lead it won't work analog and digital totally different setup. when you connect the leads up it just kills the input amp so there is no noise.
Posted on Jul 10, 2009
1helpful
How do I connect the audio from a Panasonic to p50-s1 to a marantz nr1403 so that I get surround sound audio?
The Audyssey setup does not use any audio from the TV. Audyssey is started automatically when you plug in the calibration microphone. Once you start the setup, it will output a calibration tone to each speaker. (Read the Audyssey setup instructions.) There is 1 digital audio optical input on the back of the NR1403. You will need a optical digital cable for the connection. Once connected, you'll need to use the input setup menus to select that digital sound input to go with the video input you are watching. Check page 15 of the manual.
1helpful
I bought a second hand marantz receiver. my problem is when i push the cd button the display read like this: CD/DIG2/STEREO/NO DATA and the it will go back by it self to CD/DIG. what should i do? please...
the receiver is ok. it is telling you that CD is assigned to digital #2 input, surround mode is stereo and there is no input signal. You need to connect a source to digital2 input (coaxial or optical) and you'll get sound from it.
MY MARANTZ CD-5001 PLAYS FINE WITH ANALOG CABLES, BUT THERE IS NO SOUND WHEN I USE DIGITAL CABLES.
Well, we would need to know tyo what it is attached and that it is correctly configured to reproduce the digital input from the CD player. Have you triee BOTH optical and coaxial outputs?
2answers
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
My marantz sr5200 dont reproduce dobly digital signals , maybe junt 2 channels.
I have the Marantz SR5200, unable to get the Set-up / t.tone button to work, don't have the instructions,
On the digital input 1 have the coaxial cable hooked up to blu-ray player but i have no sound, but if i hook up optical i do have sound.. wrong coaxial cable
Possibly a bad cable, but not likely its a 'wrong' one. Any RCA-style cable will do for SPDIF coaxial digital signals. Try another one. Are there other Digital Coaxial inputs you could try to prove the function?
You may have to configure your Digital Inputs so the receiver knows Digital Input 1 is Coaxial.
2helpful
Input signals Marantz SR4003
There are four digital connectors on the back of the unit: 2 optical and 2 coaxial. They are marked a s 1 2 3 4. 1 and 2 are optical, 3 and 4 - coaxial. Also you have front optical connector marked as F.
You can connect 5 digital sources to your receiver. For example, connect your DVD to input 2 (optical) by optical cable and connect your DSS to input 3 by coaxial cable. Assign DVD to digital 2 and DSS to digital 3 in input setup menu.
Playstation 3
I assume that the Marantz has an Optical lead input. If so you should connect an digital optical lead directly between the PS3 and the Marantz receiver for the sound while keeping the HDMI lead to the projector for the picture. You will need to configure the PS3 to be outputting the sound to the optical output (done through the settings menu).
Top Marantz Audio Players & Recorders Experts
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
