It is sort of broken. See if you can manually reset the unit to conditions when brand new in box. Try unplugging unit. then push in and hold the power button for about a minute. then reconnect to power and turn on. If it still does the same, , the main board is at fault.
check power settings by opening control panel -> power options. Check when is the computer set to go to sleep and when to turn of the display. This might be caused by Windows power settings that put the computer to sleep to save power.
Your hard drive may be dying and cannot read files as fast as it should. A brand new windows installation should boot withing 1-2 minutes. Having a bad hard disk would also be the cause of your windows corruption in the first place. Listen to your computer boot up and see if it makes and identical clicking patterns, you will hear clicking regardless but make sure they stay random. if your disk is dying you will hear the same click over and over as it tried to read a specific file.
You might want to try disconnecting everything EXCEPT the power cord. If you still get the red power light (it should stay there forever) then bring the gateway to Radio Shack or somewhere they have a 5 volt DC @ 2 amp power supply and plug it in for 5 to 10 minutes and see if the power light then stays green. If it stays green then all you need is a new power supply! If not, then the gateway is fried. Mine keeps going from a solid green power light to a flashing green power light and I can hear a relay click every 2 minutes at which time a pop-up say "ethernet line disconnected". I tried new power supply etc. to no avail! It is fried after 1.5 years! No more 2wire for me!
I am not sure, but usually it should have a red/yallow led while charging and green when charged ! Read your manual.
Also, check power settings in control pannel. There, you can find power schemes that turn off your laptop automatically when some time pass.
Set NEVER when plugged on power!
Check screen saver settings (and turn it off - NONE)
Also it should not turn off if there is any user activity!
At the end, if you are sure that there is no problem with your power unit, than checking and setting power OPTIONS in control pannel, should solve your proplem.
you might have just gotten your lines crossed backwards when you do a steering pump with line change out the fluid doesnt stay with the steering gear box
start vehicle after filling the pwsp.
turn wheels both directions for at least a minute with pwsp. cap off watch the fluid if lowers then its going to gear box where its required to stay the wineing is something the box does when its brand new it has to broken in like shoes propper fluid is a plus
The type or memory in the camera requires a charge in order to store data. So if you have any pictures on the camera it will constantly be pulling a charge from the battery until the battery is completely drained. If you have this problem even with a brand new battery it's possible that the memory may be corrupt and needs to be cleared. To do this just remove the battery and press both buttons several times each to make sure that the camera is completely discharged, replace the battery with a brand new battery and try again. If that fails I'd get in touch with customer service for a replacement.
