Question about Saniflo Saniplus Macerating Pump
Cant get the lid over the rubber on the older saniplus to seal unit
It seems to be very tight
Posted by trevor sutton on
Wayne Holden
  • 512 Answers
Sure hope you got that fixed. If not you can try to make the rubber more flexible with heat, either a towel/rag soaked in hot water and then applied to it for a few minutes or a hair dryer on low blowing on it for a few minutes (be careful you don't burn the rubber).
Posted on Oct 07, 2012
On a singer solid state 93220 the bottom bobbin thred is to tight how do I adjust it?
If the bottom seems too tight you must loosen the top tension. If this doesn't seem to work to well then tighten the bobbin some. I've attached a guide on how to adjust tension.
Jun 04, 2015 | Singer Sewing Machines
Rally 4. The steering seems to be stiff or tight.
hi,
ok now carefull tip the scooter onto one side, look at where the steering column attachs to the main frame, it's here you should find a bearing type collar, now you need to losen this and lubricate with a light gears, best to use a waterproof gease then tighting the collar up but
not too much otherwise your steering will again become tight.
Regards
GeWiz.
Feb 15, 2010 | Pride New Mobility Rally 4 Wheel Scooter
I installed the tank on the bowl hand tight, but it seems loose
thats a tough call, i used to battle with this when i was out in the field fixing many toilets,...if it don't leak, it's tight enough,..concerning the rocking, i used to place little shims under tank to stop it rocking,....don't force nothing,.and make sure your hand tight is good-n-snugg. good luck, good question, cracklin joe
Jan 04, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Car won't steer , fliud seems o.k. and belt seems intact
Is belt tight....must be tight.
Every model will steer even if pump / steer rack is faulty but will be very heavy..is this the case.
Dec 23, 2009 | 1993 Chevrolet Lumina
THe ribbon seems to be pulling too tight causing
In case of tec printers you can adjust the ribbon motor voltage in the parameters or adjust set menu depending on the model
Aug 19, 2009 | Office Equipment & Supplies
Ice not strong enough to push open ice maker door
twtw7771
You said,
The ice maker door seems to have a tight spring or something because when the ice goes in the chute and then backs up.
The door needs to be replaced because it is bent or out of alignment!
How old is the fridge??
Now a days you have a 1 year warranty!
Or the seal is not tight and air gets inside past the door and then the moisture freezes on the spring.
Sep 20, 2008 | Refrigerators
Saniflo Saniplus Macerating Pump Logo
85 people viewed this question
Top Saniflo Plumbing Experts
Bill Johnson
Vernon Taylor
Tom Chichester
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
