Bialetti Brikka Espresso Machine Logo
Question about Bialetti Brikka Espresso Machine
Poor or no foam bialetti brikka - Bialetti Brikka Espresso Machine
2 Related Answers
Anonymous
SOURCE: bialetti mukka express
First off, the best milk for foam is skim milk (0% fat). The higher the fat content, the less foamy your foam will be.
The foam is created by the steam/hot coffee from the lower part being forced through the doohickey and into the milk. That means that if the coffee itself isn't "perfect", the foam won't be "perfect". I've found that using different types of coffee (e.g. different grinds) or filling the coffee bin to different levels results in more or less steam/pressure being passed through, so the foam is better/worse. For example, if I put too much ground coffee in the bin or use too fine a grind, it blocks the water/steam that's going through the coffee, resulting in less coffee and weaker coffee, and also resulting in less foam.
Posted on Jun 04, 2009
Avi
  • 66 Answers
SOURCE: Need a copy of instruction manual for Bialetti
hey, screw the 2 parts tight and before that check if the filter plate is not clogged. See this guide that I wrote Avi
Posted on May 21, 2011
Bialetti Coffee maker repair
Sure it can. http://www.bialetti.com/coffee/stovetop/moka-express/spare-parts-c-1_7_22_32.html or http://www.amazon.com/s/?ie=UTF8&keywords=bialetti+spare+parts&tag=googhydr-20&index=aps&hvadid=32661633397&hvpos=1t1&hvexid=&hvnetw=g&hvrand=3217975301600862448&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_53u2x7ta30_b
I need a new handle for my GB Musa 6 Cup coffee maker. I am from Quebec City, Canada. Where could I get one of these?
It's a Bialetti Musa. The GB stands for Guido Bergna, the designer.
I haven't seen handles on any parts site, just gaskets and strainers.
You might contact Bialetti Canada, or Bialetti USA and get a handle.
CANADA
Toll Free:
800.667.4978
Mail:
Bialetti c/o Stonehaven Group
1880 Ellice Avenue
Winnipeg, Manitoba R3H0B9
email:
[email protected]
USA
Toll Free:
800.421.6290
Mail:
9409 Buffalo Avenue
Rancho Cucamonga, CA 91730
email:
[email protected]
[email protected]
Apr 05, 2011 • Vacuums
4helpful
2answers
Side valve is releasing pressure too early.brikka is 3 months old
check your filter plate to make sure it isn't clogged , that could make the safety valve do it's job and go off.
7helpful
Bialetti mukka express
1helpful
Brikka don't open!!
Three approaches to this: 1. Apply more force. Easier said than done, because these things, while elegant, are always an awkward shape. If you can't get a pair of rubber strap wrenches, you might try wrapping the bottom section in a couple of layers of cotton to keep it from getting scratched, and clamping it in a vice. Get a loop of cord, hook it over the lug the handle goes onto and stick a pole into the other end. This should allow you enough leverage to unscrew the top. 2. Pour boiling water into the top section, let it heat the top up a bit, then pour out the water and attempt to unscrew (in theory, differential expansion should improve the clearances and make it easier to undo) 3. Combine (1) and (2). A.
Top Bialetti Coffee Makers & Espresso Machines Experts
Marvin
Marvin
David Shaub
Kolbrun...
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
