1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Quick Glossary
NCK = Network lock
SPCK = Service provider corporate lock
SPK = Service provider lock
Code formats you may receive for Sony Ericsson models:
Wherever possible we'll try and send you just a single unlocking code to unlock your Sony Ericsson.
However for certain models we may need to send you more than one code, even if you don't use them all.
It would be a sting of codes as per this example:
CCK: 0984118391686835 or 0984118391686835
ESCK: 0000000000000000 or 0000000000000000
NCK: 4176979876474847 or 4176979876474847
NSCK: 3908320398047435 or 3908320398047435
PCK: 2061751224321908 or 2061751224321908
SPCK: 9960493992337231 or 9960493992337231
Note: The NCK (Network unlocking code) is the main and usually the only one you'll need.
Please note:
- If you see the message 'NCK: (0)' or 'Not Allowed', this means the phone is hard-locked. The phone cannot be unlocked because there has been more than 5 wrong unlock attempts.
- If your Sony Ericsson has a Joystick, then you must press the DOWN Arrow instead of the LEFT Arrow. DOWN Arrow meaning Joystick downwards
