Windshield wipers occasionally move or flop on their own, but it wasn't a problem until there was a hard rain storm and they quit altogether. Once they were dried out they are working again. Dealer can't diagnose the problem because they are working now. Of course when I need them again they probably won't work.
SOURCE: winshield Wiepers,1998 Buickregal
apparently, something inside the wiper motor spun and now it thinks the down position is the up position.
a new wiper motor is my only suggestion since the sensors/controls in these motors arent user serviceable.
Good luck and be careful!
SOURCE: 1998 buick regal winsheild wipers
Does the wiper still make noise like it is trying to go? If so open the cap where is attached and tighten the nut on the wiper. If does not make noise you will need a wiper motor.
SOURCE: 2000 Buick Century, Spavinaw, OK, December 26,
Remove the wiper arm and check the serrated hub to see if it sheared a pin holding it to the shaft. If it is ok, then you may have a broken/loose part in the linkage. Good luck!
SOURCE: windshield wipers stop working
If they both stopped together, locate the proper fuse and replace it.
SOURCE: 2000 BUICK REGAL MY
i`m not sure what you mean by it not working properly i assume that you mean it goes back and forth like the passenger side, but it doesn`t clean the window and you put the blade on the arm correctly then the wiper may be damaged and you will have to replace the wiper blade.check and compare the installation of the driver`s side to the passenger side wiper and correct the installation of the blade
