If the player has a rechargeable battery older than 2 years, it is probably going to need to be replaced. Look at the volts-Ampere-hours rating, and replace with same volts more ampere-hours AH rating.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
It can probably be repaired, but you will more than likely have to send it to Audiovox to get it repaired. Audiovox owns Jensen. You can get a hold of them at audiovox.com.
The flickering you describe is most certainly a bad capacitor in the power supply. find a hobbiest or TV tech to do this for you. These TVs require lots of patience to remove the back cover and removing the power supplies. Good luck and thanks for asking.
Mine started out like that, now flickers about an hour before it comes on. I don't turn it off anymore, it'll burn out one of these days and I'll get a better TV.
