Have a look at the port on your phone were u put the charging cord and see if the we part inside is broken or cracked and do the same on your power cord if u cant see anything wrong and u cheep u can always buy parts for them and take apart your iphone and replace the power socket
Testimonial: "neither of those ports are broken or cracked... but upon further looking, they seem burnt out (sploshes in the port of the phone and vise versa). Looks like I have be up in the morning, thanks so much."
It could be the charging cable. Our iPad quit charging and the problem was traced to a frayed charging cable, right behind the dock connector.
It is a common issue for iPhone users that their iPhone not charging when plugged in. There are many reasons that may cause this issue:
If your charging accessories aren't Apple certified, or your USB charger isn't designed to your iPhone model. It won't charge.
The power adapter or charging cable is frayed or broken.
There is moisture or dust in the charging port of your iPhone.
Something wrong with your iPhone software.
Your iPhone is water damaged.
In order to fix iPhone not charging issue, here are 6 solutions listed for your reference:
If your iPhone battery is already dead, leave it to charge for about two hours, and then check whether there is lightning bolt on the display.
Change to another charging cable and power adapter.
Force restart your iPhone. Read on this guide to force restart your iPhone according to different models: Force Restart iPhone
Clear out the charging port with Q-tip, toothpick, sticky tap or any small things. Be cautious and gentle during the cleaning process.
Factory reset your iPhone in recovery mode, or fix iOS issues with iOS repair software.Contact Apple if it is caused by hardware issues.
Source: Why Is My iPhone Not Charging When Plugged In?
This phenomenon is likely to be a battery problem, or is actually a hardware problem. Suggest that you can go to this site to seek help. iphone parts samsung parts iphone 6 parts YDT parts
Sounds like you have damaged your charge port. You can replace the port and get your phone working again with a replacement - iPhone 4S Charge port
It's not the cable, neither the dock connector, My Iphone 4S is not charging at all, it remains on the red line.
What could it be?
any inputs please.!
SOURCE: My Iphone 4s died from a low battery and now it
Check your charger in a different iPhone, or the sync cable also. Check to see if your dock connector isn't tarnished, if it is clean it with a CLEAN DRY used toothbrush. Has your phone been wet? These are all the typical culprits when a phone will not charge. I hope it isn't the wet problem! Good luck!
