OKI C9500dxn Led Printer Logo
A
Anonymous Posted on Aug 02, 2012
Oki C9500 TONER ERROR
Cyan toner sensor error
5 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
  • Posted on Nov 13, 2007
SOURCE: toner sensor problems
On the base of machine after removing drums and transport, there are 4 sets of 3 pins that connect to left hand bottom of each drum, these can get toner on them and not make proper contact, each set of 3 pins just pop out with the help of a flat blade, out of base to be cleaned. in yout case just switch the set under the cyan with another lot from different colour.
I am taking it that you are using genuinne non imported oki drum and toner. If this doesnt fix your problem then you must have fauly drum/toner
A
Anonymous
  • Posted on Apr 25, 2008
Hi i have the solucion a error of sensor black oki c3100. For two times i have the problem and a long time study the problem. it´s the solucion. Because i spanish the solution is in spanish languaje.
Desmontar la tapa semitransparente redonda del lateral.
El sensor lleva un iman incorporado que dice a la impresora cuando el toner se a agotado. El polvo de impresion lleva impurezas o las ponen a proposito y hacen que el iman no pueda levantar la leva que hace contanto con el sensor. Con un destornillador limpiar las impurezas que estan pegadas al iman por dentro del toner. Cerrar y listo. YA FUNCIONA JAJAJAJAJAJAJAJA.
Jeff Hughes
  • 97 Answers
  • Posted on Dec 07, 2008
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Anonymous
  • 4 Answers
  • Posted on Apr 23, 2009
SOURCE: Toner Sensor Error - Cyan. I got this error after
If you have a lexmark disregard this because their printers wont reconigze most refilled ink cartriges even if its done by proffesionals such as wal-mart est. (warranty also does not cover refils you'd need to buy a new one) what you need to do is take it and get it checked to see if they put the coulor ink in right if they did, then gently wipe the sensor on the printer, and the brass part of the ink cartridge above the ink part, put it back in and see if that works. And lastly go to your printers driver and see if you can reset the toner levels from there manually, if you cant try turning off the sensors or tricking it (google various methods) or buying new cartridge
Anonymous
  • 125 Answers
  • Posted on May 24, 2009
SOURCE: 540 : y toner sensor error
Hi moneybaggz52:
Here is your problem.
Symptom:
When setting up a brand new C5100n or C5300n out of box, a toner sensor error is encountered.
The printer can display any one of the following errors:
543K: TONER SENSOR ERROR
540Y: TONER SENSOR ERROR
541M: TONER SENSOR ERROR
542C: TONER SENSOR ERROR
Cause:
This generally can be caused by two things.
1. The toner cartridge lock lever is not in the correct position.
2. The Transfer Belt lock levers are not in the correct position.
Resolution:
Check the appropriate toner cartridge lock lever (Shown below) and make sure that it is in the correct position.
0.110?openelement&fieldelemformat=gif 2.1ac?openelement&fieldelemformat=gif
CORRECT POSTITION INCORRECT POSITION
Check both transfer belt lock levers (Shown below) to ensure that they are in the correct position.
5.2eea?openelement&fieldelemformat=gif
CORRECT POSITION
10.4086?openelement&fieldelemformat=gif
INCORRECT POSITION
Hopes this helps
Where does oki c9500 waste toner box located
Your printer does not have a waste toner bottle. Waste toner is stored within the transfer belt. When full it will give you an error indicating its time for a new transfer belt.
OKI C9800 CYAN TONER SENSOR ERROR
remove drum units and clean optical sensors located at the back end of he drum slots and clean corresponding reflective plates on drum units
Exactly what is the error on the operator panel?
Okie C5400 giving 162: Fatal Error
This is a Toner Sensor Error, Color:Cyan
and can be corrected by checking that the Cyan toner lock lever is correctly in position.
1helpful
Fatal Error 162
I am pretty sure this is the result for your 162 code:
When cyan toner sensor error has occurred
Try reseating your toner carts.
Color registration problem for Oki Data C9500
Brain-storm .... simple solution .... REPLACED Magenta Drum.... works as good as usual, but is still and always been out a little - very strange, depending on the stock, if I'm using a 10pt coated stock, color registration has always been a little out ( when the cyan and magenta are being used ((together)) - purple - dark blue etc ...)
Oki C9500 Printing Problem
Check the LED Head and LED Connection. The LED heads are interchangeable, BLK, Cyan, Magenta, Yellow.
2answers
Toner sensor problems
sensor window on the drum is closed - or the r/h side of the printer has a sensor that needs cleaning.
3helpful
2answers
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
