Question about ASUS LCD Monitor
How do I remove the blue box in the middle of screen on the asus VS208NR
Posted by rbeach99 on
Dean Kershner
    Problem Solver:
  • 12 Answers
Unplug the power from the monitor, wait for 10 seconds, plug back in. Worked on my ASUS Monitor
Posted on Feb 07, 2013
murf427
    Master:
  • 336 Answers
If you are using a Windows op system you should go to the control panel and double click on display. IN display you can select monitor A or B and do lots of stuff like set the resolution, change the orientation and lots of fun stuff. In there you should be able to turn off whatever is causing the blue box.
murf427
Posted on Aug 03, 2012
My asus laptop display is showing a blue or purple haze bar through the middle.
sounds like you are right there do it before the warranty runs out!
Dec 09, 2012 | ASUS G73JHA1 Notebook
A small little blue box appear in the middle of my screen with OSD locked and after 10 seconds it changes to OSD unlocked and it doesn't go away!!!
hi,
please browse the following site
I have a RAZ 3, cingular service and at the top, middle of my screen is a ..... Hi, wondering what the the blue blinking icon which what appears to be 2 small white ... I notice it after Ive had my cell off for awhile and turn it back on. ... and at the top of the screen it looks like a little box with an A in it, ...
www.askdavetaylor.com/what_do_all_the_icons_on_my_motorola_razr_v3c_phone_mean.html - Cached - Similar
May 30, 2011 | Office Equipment & Supplies
I have a yellow box in the middle of the screen [sony proj sc50
the light filter on the blue lcd panel is fried due to excessive dust and heat. you may need to replace the entire optical engine if you cannot find the individual piece.
Nov 12, 2009 | Sony VPL SC50 projector lamp Projector...
Blue screen only
Hello, I sounds like you either have sypbot or virus. So, reboot pc and when first boots up, hit f8 and keep hitting it until gets into saft mode and run virus scan and delete temp internet file and clean your computer.
Sep 26, 2009 | Asus Eee 701Sd Notebook
ASUS P527 Mobile stuck on Blue StartUp Screen
Firmware is corrupt you need to hard reset it,
Press Reset hole with stylus tip and power on the phone and then follow the instructions on screen.
Jun 06, 2009 | ASUS P527 Smartphone
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
ASUS LCD Monitor Logo
2,537 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
