Honda 5.5 HP GCV-160 7/8 x 1-13/16 Vertical Shaft GCV160-N5R Logo
Posted on Aug 02, 2012
I broke the gun...i need to replace the entire gun on a Honda GCV 160 5.5 hp...
I need help changing out the entire gun on the power washer...i unscrewed the cap on the handle of the gun...but i dont know how to disconnect the entire gun from the hose...
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 05, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
304
Points
Have you tried totally taking the gun apart
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on May 16, 2009
SOURCE: how to disconnect power hose from s2600 simoniz gas power washer
Just unscrew it like you would a garden hose and pull it out.
Anonymous
  • 10 Answers
  • Posted on Dec 10, 2009
SOURCE: MY HONDA POWER WASHER
sounds like its broken
Anonymous
  • 57 Answers
  • Posted on Dec 19, 2010
SOURCE: We have a Honda GCV 190 gas pressure washer. It
check that the fuel tap is on
1helpful
I have a troy-bilt model 020296 power washer. what type of replacement spark plug does it take?
Tom, NGK BRP6ES ,Champion RN9YC,Torch F6RTC are replacement sparkplugs for Honda GCV 160 pressure washer engine. This info should be in your pressure washer engine manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bsppwebtools.com/data/manuals/020296_0esAw.pdf
Troy Bilt 020296 Pressure Washer Relacement Parts
Spark plug cross reference
How do I replace top crank seal honda GCV 160 engine
its not going to matter if the seal is leaking damage alreay done to it run it till it stops or lockes up
Trying to get a manuel for Honda power washer GCV 160 lan5rn81
l
here is the link for the honda GCV160 engine. http://lawnandgarden.manualsonline.com/manuals/mfg/honda_1_2/gcv160_2.html
There must be another model number for the pressure washer. Check the pressure washer again and search that model on manualsonline.com
I need a owners manual for a pressure wahser GCV 160 from honda
MiTM will have that. See mitm.com Honda makes the motor but not the pressure washer. Honda does have manuals if you need one for that GCV160 motor.
I needed gap setting for a hnda over head cam gcv 160 5.5 h/p [valves setting ]
.006in on the Intake and .008in for theExhaust + or - .002in
Jul 02, 2012 • Motorcycles
1helpful
I have a Honda GCV 160 pressure washer from TROY-BILT and when I start the washer the motor starts but when I use the Spray Gun the motor stops and the pressure washer is jam. I think it is the motor and...
Mine is doing the same damn thing! Trying to figure out how to take off the high-pressure hose connector because I need to inspect it for clogs.
Jan 06, 2011 • Garden
9helpful
3answers
My almost new Honda GCV 160 engine will not start.
Hi , I think you need someone to remind you these engins are not made by god and they work by obeying three simple rules ,
1.Spark , Can you see a very good blue spark
2.compression,,can you feel strong compression ,
3.fuel , is the right amount of fuel getting in , is the air mixture good ,
Now try these things
Find the manual and PROPPER set the gap in the spark plug ,
clean and check the air filter ,
remove all fuel and replace with brand new,
check the fuel filter,even in the tank tap?
undo the screw at the carb bowl , can you see petrol leaking ,
If everything checks out then try this to get it started,,
spray "easystart" in the carb , bypassing the air filter ,
if it wants to start but cant for long then its a carb problem
check float hight , float needle,jets and pins ,too much air getting in
find someone thats good on motorbikes , They like me know all the tricks to get things to start ,
Fuel mix for a excell VR2522
should be a honda gcv 160 5,5 horsepower engine.
do a search for honda engine carburretor adjustment, plenty of pages on the internet detailing how to adjust carbs, mixture etc.
Excell Pressure Washer Model VR2522 Replacement Parts repair kits ...
lok at this site , parts breakdown of engine etc
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
