SOURCE: Scandisk curropt
You'll need a CF reader/adaptor for your computer, and software such as this http://www.softwarepatch.com/software/smartrecovery.html Just type "recover CF card data" and you'll find a host of downloads.
SOURCE: canon EOS 400D dslr will not work various CF
Using a flashlight, check thru the CF memory card reader if there are some pins that are bent, missing (broken) or damaged.
If this is the case, it is necessary to have serviced the camera to replace such pins, and inspectd for the broken pin pieces that may be stuck inside the camera, and cause later a short circuit.
If all the pins are in good conditions, may be the internal memory reader circuitry is failing, which requires also a professional camera repair service.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing to open it and perform the steps to repair it.
If so, You will need tools to do it, which includes the usage of a soldering iron, microscope (since requires micro soldering), and buy the CF memory card reader connector..
Best regards,
SOURCE: Canon EOS 400D - Error
Look inside the card compartment to check for broken or bent pins. Have you tried formatting the card in the camera? This will erase it so download any pictures first using a card reader if necessary.
