It will make copies but won't send or receive any faxes
I'm assuming you have the line in the line port in rear of the copier and that the line is good. You may have a bad NCU board or the interface board. Open up the back of the copier and you should see both boards on the lower left side. I would try the one board on the left and if that doesn't work try the other board. Good luck.
SOURCE: multiple fax copies only 1 or 2 get through
First check to see if all 5 are bing sent. Sometimes paper sticks to each other and you may only see 1 or 2. Also your telphone line has a lot to do with it. If you are using a digital telephone line with your internet line such as a vontage telephone, the signal is takene from your internet line for your telephone and sometimes such as when you are on the internet and trying to fax, you do not have enough signal strength. sometimes sutting off the internet works. Also what does the report say from your copier/fax are 5 pages being sent. In the set up this Canon you can get a report after you send a fax....
SOURCE: no can scanner and send fax,only copies
You need to download the vista driver for the canon IR1023if here is the link for drivers http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2277&modelid=14596 (GO Vista) Hope this helps
SOURCE: We have a 1025iF Canon copier. I'm trying to
hello.
the first counter 101 is total of the machine every paper that gets out of the machine(print,fax,copy,reports)and the 201 its only about copys.
SOURCE: we just got the 1025if cannon imagerunner. I
look under additional function then timer settings
