Question about Motorola Mobility RAZR V3xx Cellular Phone
Motorola RAZRv3xx text message inbox, want newest at head of list
The inbox used to open showing the most recent messages at the top of the list. Now it opens with the oldest messages at the top (I can scroll to the newest but it was easier the other way and my brain is used to seeing the new ones on the top of the list instead of the bottom... and why would I want it to open the old messages first?)... I've tried all the options I can find in the phone and nothing returns it to the original and most useful order, I want the newest messages at the top of the list when I open the inbox.
Posted by Wendy Nailart on
1 Related Answer
vqcb43
Motorola Mobility
  • 1623 Answers
Mobile Phones and Acessories
    Verified Fixya Pro
    SOURCE: How do I record outgoing message on Motorola L703 Phone
    1-888-331-3383
    Mon-Fri 7:00AM-7:00PM CST
    (Corded/Cordless Phone email)
    My Moto Support
    Mark
    Motorola Support
    Posted on Dec 19, 2014
    I want to delete all message of my inbox at once, how?
    To delete all your inbox messages at once, go to the inbox, select the options, then scroll till you see mark, then a checkbox will show up on all the message in the inbox, then you check all, once you are through checkin, you press option and select delete all checked.
    All the messages in the inbox will be deleted. Try it out and see.
    Sep 14, 2011 | Motorola Mobility W220 Cellular Phone
    How to open my mms
    when you rec a msg / picture Select Show to open the
    message. To open a message in Inbox, scroll to it, and press middle button
    May 19, 2010 | Nokia N70 Cellular Phone
    My screen show i got 1 unread sms but i cant find it
    check whether you have moved any unread messages into other folders. if not reply me..
    Apr 05, 2010 | Sony Ericsson XPERIA X1 Smartphone
    My blackberry shows texts from oldest to newest
    When you look at messages, exit and come back, the screen will be exactly where you left. The device doesn't reset to the top. Just use the T for top and B for bottom buttons.
    There is no real setting for the blackberry to show old messages first. I am assuming that when you are showing your messages, you may be at the bottom of the list. Try using the above to be at the top of the messages list.
    Oct 25, 2009 | RIM BlackBerry Pearl 8100
    Deleting text log from a711 samsung phone
    Access menu>messages>(Now from this screen you should see your Inbox, Outbox, Drafts, Saved, Etc. Check to see if you are given 'Options').
    This should allow you to delete all text messages in each category. If you are not given an 'Options' feature then access your Inbox and from your Inbox use your 'Options' feature to delete all clutter.
    Thanks.
    Apr 02, 2009 | Samsung SGH-E720 Cellular Phone
    AT&T Yahoo! Mail could not load this message
    have you signed off then back on?
    That may fix it.
    Mar 26, 2009 | Yahoo Mail
    How do I delete text messages from Inbox on Motorola V220?
    first press menu, select messages, then press menu button again, scroll down to cleanup messages, select, then scroll down to which box you want to delete and select. done!
    Mar 25, 2009 | Motorola Mobility V220
    Error: P-1
    I had this problem on a Fusic (LX-550). The error occurs because a picture mail is corrupted that you're currently trying to preview (inbox). The Fusic inbox shows 3 pic mails at a time. If one of the three is bad, you'll get that error. If the bad pic mail is the most recent in the inbox, then send 3 pic mails to yourself to bump the bad one to number 4. This should allow you to get to your inbox without the error, although you still have to avoid the bad pic mail page(move up in the inbox to see you're oldest mail). Sending pic mails to yourself one at a time is one method of narrowing down the bad pic mail. The permanent fix is to install bitpim, edit->detect phone, view->view file system, navigate to /EPM/MediaStore/MessageStore and delete the offending pic mail. The file name with the highest number is probably most recent. Right click on the file and perform a hex dump to read the message time stamp. Do a backup first and view the hexdump to verify you're deleting a pic mail file. Good luck!
    -Joe
    Dec 15, 2007 | Cell Phones
    Motorola Mobility RAZR V3xx Cellular Phone Logo
    160 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Thejus Mt
    Thejus Mt
    Level 1 Expert
    Lawrence Oravetz
    Vernon Taylor
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
