Question about HP Compaq ProLiant DL380 G4 Server
Dl380 g4 rbsu stuck in text mode how to revert to mouse mode
Rbsu is in text command mode want to return to default
Posted by robert feldman on
3 Related Answers
Anonymous
  • 339 Answers
SOURCE: hi i have many hp dl380 g4 and i did not
There is no "default". Each is unique from the factory and is printed on a tag hanging from the front of the server when it is delivered. You will need to contact HP for help with this.
Posted on Jan 08, 2010
nicarta
Nicholas Enyika
  • 506 Answers
SOURCE: Is there any procedure to boot DL380 G4 in single
Connect the keyboard, mouse, monitor, network cable and power cord. press the power button on the front panel of the server. If the OS is installed the server will boot.
Posted on May 28, 2010
Jonny Law
SOURCE: HP DL380 G4 Video resolution
To increase the resolution on a DL380 G4 try this.
So here is what I have done.
- Download x64.zip file from ftp://ftp.supermicro.com/driver/VGA/ATI/RageXL/x64.zip
- Run/Expand the zip to same directory
- DO NOT run the setup file or you will get the error message,
"Setup will only run in Administrator mode. Setup is aborting"
- Launch Device Mgr
- Expand the Video Driver and update Standard Video Drive. Point to directory x64.
- The server will need to reboot
- Display settings can be raised from 1024x786(16bit) to 1280x1024(32bit)
Note: 1600x1200 (16bit) is available but does not work on mine. If you set it to this setting and the video does not come back, connect up a higher resolution monitor and set it back.
Posted on Jan 24, 2012
How do I put an apple laptop ibookG4 back into normal mode
Restart holding down: command option O and F. Keep holding down those 4 keys until you see text on a light background. At the end of the text will be 'release keys to continue'. Release the 4 keys and type: reset-nvram hit return, then type: set-defaults hit return, then type: reset-all and hit return. The iBookG4 should restart with all default settings restored.
Oct 20, 2014 | Apple G4 Computers & Internet
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
My hp proliant dl380 g7 server shows non disk error
Enter RBSU create Raid & Select Direct Attached Storage option in boot controller,
May 17, 2012 | HEWLETT-PACKARD HP ProLiant DL380 G7 Entry...
Is there any procedure to boot DL380 G4 in single mode ? Thanks
May 17, 2010 | HP Compaq ProLiant DL380 G4 Server
Hi ihave apple power book g4 i want reboot
login in single user mode as below:
Starting up in single-user or verbose mode
    1. Shut down the computer if it is on.
    2. Press the power button to start the computer.
    3. Immediately press and hold the Command (Apple) key and one of the following:
    • the "s" key for single-user mode. (Command-S)
    • the "v" key for verbose mode. (Command-V)
You have successfully entered single-user or verbose mode when you see white text appear on the screen.
Once you are in the Single user mode type the following:
fsck -fy <then press enter>
If this command returns with an error or reports that is found an error but fixed it then run the command again and repeat until the drive checks good.
Once you are done with the repair or feel satisfied, type 'reboot' and press enter.
Feb 12, 2010 | Apple PowerBook G4 Mac Notebook
Hi i have many hp dl380 g4 and i did not work with ilo before , when i tray to access web ilo aksed me for user login and password and i do not know it ? what is the default and who i can reset it
Jan 04, 2010 | HP Compaq ProLiant DL380 G4 Server
APPLE IMAC G4 - TRYING TO INSTALL OS WITHOUT DISK EJECT BUTTON
Reastart the iMac and at the same time hold down the mouse left click button. If that does not work.
  1. Restart the computer.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  4. At the prompt, type: eject cd
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
Dec 11, 2009 | Apple iMac G4 Desktop
No display on DL380 g4
This can be caused by a processor / VRM issue or even a system board fail. Try dropping to a single proc and VRM and swap test with the others.
May 01, 2009 | HP Compaq ProLiant DL380 G4 Server
Boot problem with a ProLiant DL 380 server,
To enter the BIOS of a ProLiant DL380 you have to press "F9"
Jan 23, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G4 Server Logo
62 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
