Question about Frigidaire FAFS4272LW Washer
Fridgidaire fafs4272lwo door open error
Door open message door ,closed no separate door close button
Posted by jtwardy on
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Make sure the latch is not broken on the door. Retry. If this continues contact a professional so the latch and door assembly can be diagnosed. Also check to see if the door is sagging down at all.
Posted on Aug 03, 2012
3 Related Answers
John Broderick
  • 82 Answers
SOURCE: door won't close
Sounds like the door 'interlock' has failed.
Hope this helps
Posted on Sep 30, 2009
Prakash R
  • 1382 Answers
SOURCE: frigidaire affinity door will not
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Posted on Apr 22, 2010
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: When Start button is pushed,
Hi
You are right....dr is a door lock circuit error which means that the door lock-switch assembly has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 20, 2011
Konica DiALTA Di1611 error message 2nd side door open although the door is closed.
Check and clean the sensors and actuators,verify the cable connection,verify if 5V appaire to red cable.
Apr 09, 2013 | Office Equipment & Supplies
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
The printer will not print, and it keeps saying that the printer door is open, but it's not. I just replaced the cartridges, but I made sure the door was closed. How can I get this working?
You may try the following to resolve the issue,
  • Open, and then close the cartridge door of the product. Make sure that the door rests securely against the body of the product.
  • Check if the error message still displays. If it does continue with next step.
  • Inspect the cartridge door and the area around it to make sure that no obstructions prevent the door from closing completely.
  • Press the Power button to turn ON the printer.
  • Disconnect the USB cable from the back of the printer.
  • Disconnect the power cord from the electrical outlet.
  • Disconnect the power cord from the printer.
  • Wait 30 seconds.
  • Reconnect the power cord to the electrical outlet.
  • Reconnect the power cord to the printer.
  • Press the Power button to turn on the printer.
  • Reconnect the USB cable to the printer.
  • If the error is still there you need to send it for repair, as the sensor for the door might have gone bad.
Regards,
Shrey
Jun 05, 2011 | HP PSC 1315 All-In-One InkJet Printer
I cannot clear the "Door
Hi
When you open the print cartridge access door there is a black toggle switch that needs to be in the depressed position to let the unit know the door is closed. If the cartridge door is not completely closed, the error message displays.
1. Open, and then close the cartridge door of the product. Make sure that the door rests securely against the body of the product.
NOTE: To see how to close the cartridge door of your specific model, see the cartridge section of your product's User Guide.
2. Check the product control panel to see if the error message still displays.
If the issue persists, see the next step.
Check the cartridge door for obstructions
1.Inspect the door and the area around it to make sure that no obstructions prevent the door from closing completely.
NOTE: Bits of paper, packing materials, and tape might prevent the door from closing completely.
2. Remove any obstructions.
3. Check the product control panel to see if the error message still displays.
If the problem still persists you need to reset the product...
1.Press the Power button to turn on the product.
2.Disconnect the USB cable from the back of the product.
3.Disconnect the power cord from the electrical outlet.
4.Disconnect the power cord from the product.
5.Wait 30 seconds.
6.Reconnect the power cord to the electrical outlet.
7.Reconnect the power cord to the product.
8.Press the Power button to turn on the product.
9.Reconnect the USB cable to the product.
10.Check the product control panel to see if the error message still displays.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 10, 2011 | HP OfficeJet 7130 All-In-One Printer
My p0rinter is not printing with good color quality. Blue doesn't pick up. I ran the troubleshooting and the error code 3502,3501,,3830, comes up. How may I fix this? I have new cartridges. thank you....
This is from the Kodak website.
How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? Published 08/25/2010 11:38 AM ' Updated 01/07/2011 08:40 AM ' Answer ID 1467 How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
Feb 07, 2011 | Kodak ESP 5 Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
'user door open' error -where is the 'user door'? We have opened and closed all the parts we can find that open and close.
the door you open to put the cartridge. If the door is closed and you still get the message, it means the door is not activating the microswitch when the door is closed. There must be a tab on the door which presses the switch.
May 22, 2009 | Dell 1815dn All-In-One Laser Printer
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Back door closed
I did not get any error message but the 6940 printer would not print. Instead "Ready" the printer said "door open". When I deleted printer and plugged the usb cable back in the XP machine found the new hardware, said "Ready" and could print.
Dec 22, 2007 | HP Deskjet 6940 InkJet Printer
Frigidaire FAFS4272LW Washer Logo
230 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
