The picture is not full screen when I use it, and having to set the screen size every time I use the TV its getting old.
There may be an active lock for setting changes. Look through the settings of the input device and check whether that has got changed.
Posted on Aug 03, 2012
SOURCE: cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Posted on Feb 18, 2008
SOURCE: Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Posted on Mar 23, 2008
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
SOURCE: Problems with the picture mode on my samsung 46''
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
Posted on Jan 22, 2009
