SOURCE: change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
SOURCE: Call service 7000:0165540 FS 2000D
Are you using manufactures toner, my guess are it is after market toner or not seated correctly, or the toner cartridge has a busted gear, either way.. try a different toner cartridge. 7000 error indicates the toner motor cant turn. the 0165540 is the page counter;
Toner motor lock error
A motor over-current signal is detected
continuously for 5 seconds since the
toner motor is activated
;) hope this helps
cheers
SOURCE: Kyocera FS-4000DN Laser Printer call for service
that's just a toner motor error..most likely the toner was not put in properly..remove the toner than reseat the toner making sure it snaps secure into place..you should than be fixed
