Question about Exercise & Fitness
I need some replacement parts for my elliptical trainer. Where can I find them?
Posted by andrew moniz on
frank chong
    New Friend:
  • 23 Answers
The first thing you should do is check with your manufacturer. Not only should you be covered by warranty, but they should have the right parts for your machine. If your warranty is expired or the manufacturer has gone out of business, you should look elsewhere for parts specific to your machine; however universal parts may also do the trick. If this is the case, you may want to consider buying used parts.
Posted on Aug 02, 2012
Need exercise manual.
I may be able to assist you if you can please supply the make and model of your elliptical trainer.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Sep 03, 2015 | Exercise & Fitness
Why is the Precor AMT 100i Adaptive Motion Trainer Elliptical primary belt making noise and should I adjust it?
SOmetimes belts make noise when they are worn out and need to be replaced - belts like that are considered 'wear' items, like tires on a car - they have a very limited lifespan compared to the other parts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Jun 18, 2014 | Precor AMT 100i Adaptive Motion Trainer...
Is buying a refurbished elliptical trainer a good deal?
Most elliptical machines that have been refurbished are around 2 years old. Essentially, the machine is cleaned up and broken parts are replaced. Refurbished machines can sometimes look used, but if that doesn't bother you than it may be worth buying one if the price is right.
Aug 02, 2012 | Exercise & Fitness
My elliptical trainer is starting to squeak. What should I do?
Don't worry; this is a common problem in elliptical trainers. Over time, parts of the machine may start to squeak. I am going to attach a how-to guide that will explain what to do when this happens.
http://www.livestrong.com/article/269134-how-to-stop-an-elliptical-from-squeaking/
Will using an elliptical trainer hurt my knees?
Quite the opposite. Elliptical trainers are great for people with knee injuries. Elliptical trainers limit the strain on your knees because it is a non-impact machine.
Need to replace the drive belt on my Schwinn 430 Elliptical
http://download.dfxi.com/supportdocs/SM/Schwinn/SCH_430_431_450_SM_RevC_web.pdf
Follow this link for step by step instructions. Note you will need a crank puller which you can purchase at most bike shops. remove both covers then crank weldment(discs).
Jan 19, 2009 | Schwinn 430 Elliptical Trainer
Exercise & Fitness Logo
168 people viewed this question
Top Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
