Question about KitchenAid Dishwashers
Kitchenaid dishwasher how to unlock child lock
Posted by xxxx on
Henry Matos
    New Friend:
I have problems with the control panel, it is blocked and just turn on the clean button..
I have already done all the steps that have been reviewed and the control panel is still blocked
Posted on Sep 18, 2018
techster04
  • 155 Answers
Hi..Push the energy save button and hold for at least 4 seconds.This will solve your problem.
Posted on Aug 02, 2012
5 Related Answers
Mukesh Kumar
  • 3230 Answers
SOURCE: Child lock to turn off
Well you can please follow the below steps -
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Good Luck!!
Thanks
Posted on Mar 02, 2010
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Have a kitchenaid dishwasher KUDS25SHWH1 - the
Unplug the unit for 15 minutes then plug it back in. This should reset all your computer system and make everything work again
Posted on May 28, 2009
Paulo
  • 188 Answers
SOURCE: Child lock shut off
Hold the button with the lock until the light turns off. Consult the manual.
Can you provide a model number?
Posted on Feb 18, 2009
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
SOURCE: the child lock is stuck on my kitchenaid superba
Posted on Apr 03, 2010
My dishwasher is locked. This has never happened before. How do I unlock it?
It's probably still in a work cycle. Advance it to the end, or wait for it to finish.
Jun 14, 2017 | Dishwashers
Blinking child lock light
Under the child lock icon, push and hold the button until it beeps, this should unlock your panel. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 13, 2016 | KitchenAid Dishwashers
Child lock light is on and dishwasher will not start. How can I turn off the child lock? model # KUDS25SHWH1 serial# FJ2811738
There is a button or two with a little lock icon by them. Hold the button in for a few seconds until the lock light turns off.
Aug 03, 2011 | KitchenAid Dishwashers
I have a model KUDV245EWHY the key pad has a code to child unlock it..touch key pad..
I think you want to disable the childlock key. I think all you need to do is press the child lock key for 5-6 secs .That should disable the child lock.
Jun 01, 2011 | KitchenAid 34 in. KUDV24SE Built-in...
Child proof lock light is on, cannot run the dishwasher
To turn off the Child Lock
Press and hold ENERGY SAVER DRY for 4 seconds. The
light turns off.
Apr 18, 2010 | KitchenAid 24 in. KUDM25SH Built-in...
Wont run, how to unlock a child lock
I have a child lock on which I cannot unlock, please help
Mar 31, 2010 | KitchenAid Dishwashers
My dishwasher is a KitchenAid dishwasher model # KUDR24SEBL5.
Most of the dishwasher in this series have an energy saver dry button. Hold this button in for four seconds and it should unlock the child safety lock. Does not work, try again for 30 seconds. Does not work. We have problem. If your model does not have an energy safer button of any kind, then type in the model number and you should be able to find the manual online and open the same to find out how to unlock the child safety lock. If all fails then you need an Electronic control board assembly, about $150 plus shipping from repair clinic.com. If you are at all handy, this is easy repair. Make sure you turn off the breaker or remove the fuse before you attempt any repairs.
Feb 19, 2010 | KitchenAid Dishwashers
How do i unlock kitchenaid 2 drawer dishwasher
Did you find the answer?? Its on here....someone nicely posted it. What you have to do is hold down the ProDry button for 4 seconds and it will unlock. Apparently, this is a child-lock mechanism.
Apr 30, 2009 | KitchenAid Dishwashers
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Child Lock
press and hold the lock button for 3 to 5 seconds id this does not unlock it then you need to replace the touch panel
Nov 19, 2007 | KitchenAid KUDR25 Dishwasher
Dishwashers Logo
1,354 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
