When we put for charging, charging for 1 second after it shows not charging. pls tell me what is the problem
POWER SUPPLY & BATTERY PROBLEM
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
SOURCE: lap top will not power on
There are a few things that can cause this. Start by removing the battery and starting on AC only. Then remove the memory and try each chip separately. If these aren't the problem, then I'm afraid the power management system or another component on the motherboard may have failed. You will need to take it in for a professional diagnostics.
SOURCE: charger not charging battery and no powering lap amilo pro 3515
Your power connector on the laptop has been bumped too many times and the solder connection has worked it's way loose.. somewhat of a common annoyance. Find a good TV Repair shop, maybe a reputable PC repair shop and tell them to please resolder ( better to replace, but could cause rejection if they don't have a source for micro parts ) the connector back onto the motherboard.. could cost you $100 because of what it takes to access the location for a 1 minute solder job.. sad but true, sometimes, EVERYTHING in the laptop has to be removed to solder the connectors on the bottom side of the motherboard, sometimes you can get lucky with bottom side access. Get someone experienced in circuitboard soldering techniques. A hobbist will burn up more than what they are attempting to fix.
Toby White-Beebe
Dell Certified Lead Systems Expert
Testimonial: "thanks souds like that is the problem"
SOURCE: My lap top will not
This is a normal problem with notebooks, not to worry can be easily resolved.
Follow the undermentioned steps and check it works or not!!
1>Turn the system completely off
2>Disconnect the power adapter and the battery from the system
3>Disconnect any other pheripheral which is connected for example :Printer,scanner,flashdrive,etc
4>Press and hold the power key for 1 minute without any power source being connected to the system.
5>Now connect everything back
6>Try powering the system on.
If it works GREAT.....If not then follow the undermentioned steps
1>shut the system down
2>this time when we restart keep on tappping the F10 key for sometime which would take you to the PHOENIX BIOS SET UP
3>As soon as you reach that screen it might give you an option to click on YES or NO.
4>Yes would be higlighted click on ENTER
5>If you don't get any options like yes or no....not to worry
6>Press the F9 key once which would ask you whether you want to set the BIOS to the default settings or not, which would give you a YES or NO option
7>Yes would be highlighted click on YES
8>Now press F10 once again and then Hit enter on YES option
9>The system would reboot by itself
10>Hope it works this time
IF then also the issue persists
1>Boot the system press F10 to got to the BIOS SET UP
2>If it gives you a YES or NO option ,select YEs and then hit enter
3>look at the top of the screen you would get a DIAGNOSTICS or ADVANCED TAB
4>Selecrt that tab using the ARROW KEYS on the keyboard and then hit enter
5>Under that option it would give you an option to run a PRIMARY HDD SELF TEST
6>Run the test and in case you get any errors like #1-07 FAILED or #1-08FAILED or any other errors ask HP tp replace the hard drive of the system
7>In case th HDD test passes completely which normally takes around 120 minutes to complete doesn't give you any errors then you have to reinstall the operating system
Check this steps ....in case none of the steps work then get back on fixya would let you know how to reinstall the operating system
Regards
KEN
