SOURCE: Spongebob dvd player is not playing on Spongebob sb 314 tv
You need a TV with an A/V input option. I believe your set does not have this option.
You can look at getting an A/V modulator. Check with any local electronics store. The salesman can give you the details about how to set this up with an A/B switch so that you can select between the modulator and the cable system.
Jerry G.
SOURCE: Emerson Spongbob tv broken remote
go right now to : www.ebay.com , they have about 3 remotes available for you . hope this helps . please rate this solution thanks
SOURCE: Spongebob tv remote
contact Emerson parts supplier's number at 1-800-321-6993. They have the replacement remote control for $29.99.
Try also here
SOURCE: I have a spongebob TV
Please contact Fox-International.com for replacement remote. it's where I got mine or
just get a generic remote and any tv shop .
Actually I found there are several remotes that work. The first is the Bright House networks remote, the larger one that they provide you when you get digial service.
The second is The Universal Remove Control by GE. It's numbered 24944 in the upper right hand corner of the paper. It's sold for $4.94 at Walmart in the checkout area...
I found that manually inputting the code for the remote doesn't work. You have to do a search for the code using their method...on this particular remote from Walmart, its hold the setup button down until it lights up, then press and depress the TV button...then press channel up until the TV changes channels. It worked once, but I just kept going, the 2nd time it worked, then I pressed the mute button [to keep the code] and it works...you simply press input and it switches to AV.
I have to admit I thought it was ridiculous that you can't use this particular TV without the remote, but I was happy that I went through the effort the first time to keep trying remotes...
This is the first kids TV that I have found that you can't find the AV channel by going through the channels AND you can't hook up two items to the AV outlets because you have to disconnect the back or front ones, to use the other....PLUS it only comes with a dual AV outlet, instead of the 3 plugs [red, white, yellow] only has the white and yellow.
Thanks for contacting Fixya.
