Changing from 3 to 4 wire hookup on a electric dryer: Power cord help for 3 & 4 prong dryer cords This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business. This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Your cord wiring, while not 100% correct was not the problem.
The green wire should have gone outside the terminal cover to the grounding screw.
There is a thermal fuse next to the high limit thermostat you replaced. Check it for continuity.
Remove the wires and use a VOM set for ohm.
No reading is a bad fuse.
Also check the door switch for continuity.
No reading when closed is a bad door switch.
