Cannot print in normal mode always fine mode bec if you print in normal mode you cannot read the print same with brother dcp 165 but the difference is the magenta did not print at all
Machines of God will solve your problem add me on msn i [email protected]
SOURCE: Brother DCP-130C refuses to print the magenta ink
If you don't print at least once a month, you will clog the machine. You unfortunately have to get it fixed by a professional or get a new printer. Sorry!
SOURCE: lost my brother installer of DCP-165 C
you can download from here.
http://download.cnet.com/Brother-DCP-7020-Printer/3000-2116_4-80337.html
SOURCE: magenta cartridge is empty, how can I print in
You can't.The printer need all cartridges not empty to initialized and printing.You need to replace the empty cartridges to print.
SOURCE: I have a brother DCP-135c printer. the magenta ink not printing
The process to get to the print head will take you approx. 1 hour. Without being trained on it, there is a high failure rate upon completion.
The Scanner assembly needs to be taken off. Harness Cables for the Scanner need to be removed.The Upper Case Assembly needs to be taken off. Printhead casing and printhead tubing calbes need to be removed, printhead mainboard needs to be removed, and then you have access to the printhead.
Thanks
SOURCE: my brother printer DCP 395CN
Some printers automatically print automatic duplex printing, other printers allow you to manually reinsert pages to print the second side .and some printers do not support duplex printing at all.
To find out whether your printer supports duplex printing, you can check the printer manual, contact the printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box
Note that If you have more than one printer installed, it's possible that one printer supports duplex printing and another printer does not.
gimme your email to clarify your doubts
