SOURCE: Loud buzzing noise
Out put Capacitor breaking down - needs a serive replacement if available.
SOURCE: trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
SOURCE: connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
SOURCE: Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
SOURCE: My Sony Blu-ray DVD player isn't working with my LG HD TV
needs a HDMI™ (V1.3), tv set , or above. try to check the lg tv set is compatible to HDMI™ (V1.3).
Testimonial: "Thanks for the advice but I got it fixed myself, I had the Video Output set wrong."
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
