I have put new plugs wires cap and rotor, throttle position sensor, cam shaft sensor, ingination modual, O2 sensor bank 2. can anyone help me with what this could be?
SOURCE: 1997 dodge dakota v6 engine wont start replaced
turn the key to the on position a see if you can here a buzzing sound around the fuel tank,if you don't hear a sound then. (be very careful while doing this) with the key off take a fuel line coming from the tank loose,make sure its pointed away from you and turn the key to the on position,see if any gas comes out,if not then your fuel pump is probably bad.
SOURCE: '87 300ZX(NON-TURBO) STALLS OUT/BOOGS DOWN
overhaul of carb needed, check the vaccum advancer for wear n tear, rapace f necessary fo
SOURCE: Shakes while idling and sometimes stalls.
check for minor vacuum leak and map sensor,pcv,egr valve
SOURCE: 1997 Blazer no-start
sounds like youve really done your home work all that comes to mind now is try a cam posistion sensor this would keep your car from starting as well if that is good you can aslo try a crank sensor. you will get all of the readings that you are getting and these sensors can still be bad.
