It will definitely fit. Line up the in/out connectors on the rear edge of the board to the cutout slot on the rear of the case. Then the motherboard mounting holes will line up with mounting holesof the case.
It really depends on the compatabilty of the tower ... some towers can hold matx atx itx motherboards the way to find this out is to open the case and see if there are more ways than one to configure the motherboard stand offs most towers have a blue print of sorts etched into the metal next to the holes and it will say matx or atx or itx some are lettered like atx a-9 next to the hole or you can make a template by marking the holes from the mother board to a piece of paper and put the paper in the tower to see where the holes line up hope this helps
SOURCE: Sunbeam Transformer ATX Full Tower Case
If you can't find it HERE, then I would try Radio Shack.
SOURCE: a power supply compatible with
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139017
SOURCE: I need help with compatible parts for the case as
you can go to newegg.com
search for a MATX motherboard.
you can go AMD or Intel depending on how much money you can afford.
SOURCE: Researching power supply for Cooler
The power supply will fit... the question is what do my motherboard, video card, ans drives need in wattage. most systems will do well with a 650 watt. I like antec as a brand.
SOURCE: What power supply is compatible
Hello vonii94,
Welcome, and thank you for using FixYa!
To answer your questions, the sky is the limit! :)
Any modern power supply you would purchase, as long as it is ATX Compatible, will fit this box.
I recommend at least a 750Watt so that you have growing (upgrading) room in the PC. Antec and Cooler Master make some nice ones.
www.newegg.com or www.tigerdirect.com
Have a great day!
