THERE IS 4 VERY SMALL SCREWS IN EACH CORNER. wHERE CAN I FIND A TOOL TO REMOVE THE SCREWS
A glasses screw driver on a key ring will remove them. They cost about $2.00. If you mean the ES9839 ladies fossil watch, you need Renata 379 battery or other brand equivalent.
You need watchmakers screwdrivers you can get them and other tools aswell off ebay ,,,,click on the link below,,,,,,,
http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313&_nkw=watch+makers+screwdrivers&_sacat=0
SOURCE: removing the back to change battery
The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
The original battery was Sony SR621SW.
Pay attention to the rubber seal ring when putting the watch back together.
SOURCE: For Casio F-91W how do I replace battery? I see 4
Most of these resin-case F-series Casio sport watches use a fairly large lithium coin cell battery. Once the four screws holding the watch back are removed, you should be able to just pop off the stainless steel spring clip that holds the cell in place and pull it out, without having to remove any more screws. Be careful when replacing the clip, because it is asymmetrical and goes in only one way. Also be careful not to lose the tiny spring contact that connects the watch movement to the piezoelectric sound element glued to the watch back. If you lose the spring, the watch will still run, but the alarm won't sound anymore.
SOURCE: POD watch battery replacement.
Unscrew the screws holding that contact. Memorize where each screw was - they can be different in length. Fit new battery, put contact back in place and screw all screws back exactly where they were. After that you may need to shortcut battery's+ and AC point (marked on movement) for resetting your watch. Use tweezers to do that. Rate me, plz.
SOURCE: How do I replace a battery on a kenneth cole watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
