My nokia 5330 will not sent text message they go to my outbox
For sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
SOURCE: unable to send text messages on my new nokia 5800
All you have to do is go to your message setting on your phone:
1. Open Messaging
2. On New message sellect options at bottom
3. Open settings
4. Open Text message, you should see: Message centre, message centre in use ect..
5. Open message centres this should go to next screen then open again, this screen should have : Message centre name & Message centre number (from your network provider you need to find out what is the message centres name & number are e.g in Australia it should be SMSC1 and number is +61411990001) then just manually enter these in there.
SOURCE: nokia 5800 wont send text messages
I have just had this problem, i read from an internet page about this problem, i turned off my phone and took out the battery. After i turned it on all outbox messages sent and it sends fine :D
SOURCE: i cannot send SMS using my Nokia 5230. i have alre...
i was having the same problem. back up your everything contacts, notes, images, calender entries everything and then dial *# 7370# and enter your code most probably it will be 12345 and your problem will be solved INSHALLAH
SOURCE: Text msg stuck in outbox
dial this code *#7370# then enter your lock code. and wait,,your phone will reboot.it will restore the factory settings.100% tested... please click vote
Testimonial: "I found that advice very helpful. My phone is now rebooted and I've been able to text a friend and had a text back confirming they got it! Thanks "
