When I went to open my dishwasher the right side of the pull bar came off the dishwasher
There are 2 ways the pull bar can attach, 1 : 2 small screws under the handle of the pull bar that are relatively easy to re-install ( if the holes are stripped, you will have to get a slightly larger screw ) 2 : same concept but the screws are behind the inside panel of your dishwasher. you must remove the inside front panel ( usually @ 10 to 12 small screws then replace the pullbar screws before replacing the panel. If yours is # 2, i suggest you use some loctite type material on the pull bar screws to help prevent / prolong the screws from working loose again
