Cylinder head gasket is good
If your head gasket is good, and you know this without a doubt, then you either have a cracked head/block or your head is warped. There is no other way for coolant to be getting in your oil. Heads aint any fun to take out and mess with but if you can do the work yourself it isn't to expensive to do. As long as your block is good. Good luck.
SOURCE: water in number 4 cylinder of suzuki sierra 92 model carby type
If you take out number 4 plug and look in the hole do you see antifreeze? If yes, then yes, replace the head gasket.
may be oil feed to cylinder head replace gasket
SOURCE: water/oil mixing in 22r engine
yes it can mix, also check the timing cover for rubs from the timing chain. this is the common problem with 22r. many mechanics will tell you its the block but they are just trying to make money.
SOURCE: 1991 Daihatsu charade, 3 cylinder, manual, engine
Hi ,engine oil in the coolant can only mean 1 of 2 things either head gasket or cracked block,It often takes experienced eye to see where the gasket problem is, it wont be :cracked:in that sense of the word,but I`m sure that will be the trouble... for oil to be in the water the leak will be between an oil gallery hol;e and a water jacket hole and the onlyevidence may be a darker colour between the 2 holes it wont be abig section ,or the oil pressure would have pushed alot of oil through into the water i think it is on an oil return gallery, unless there was a lot of oil.if you know an experienced older mechanic ask him to have a look at the gasket for you.I doubt it will be a cracked block ,unless you have had it realy hot and added cold water to the engine while it was hot. If not I sugest you clean every thing nicely and put anew head gasket on put it back together..If you need any help in that area, dont hesitate to get back to me and i`ll help where Ican, thanks
