Soyo Atlas DYLT3212 32 in. HD-Ready LCD Television Logo
Anonymous Posted on Aug 01, 2012
The picture disappeared on my 32 - Soyo Atlas DYLT3212 32 in. HD-Ready LCD Television
  • 6 more comments
  • Anonymous Aug 03, 2012
    Unfortunately it did not fix the problem. =0( According to the TV repairman, It would be better to buy a new one rather than fix it. I have to say that I am Uber disappointed! I've only had it for a couple of years now and LOVED it. It was such a great TV. The picture was crisp and the sound was clear. However, for this reason alone, I would be nervous to purchase another one of you products. Can you restore my confidence in your company? It truly was a great product while it lasted. Unfortunately it didn't last very long =0(
    Unfortunately it did not fix the problem. =0( According to the TV repairman, It would be better to buy a new one rather than fix it. I have to say that I am Uber disappointed! I've only had it for a couple of years now and LOVED it. It was such a great TV. The picture was crisp and the sound was clear. However, for this reason alone, I would be nervous to purchase another one of you products. Can your restore my confidence in your company? It truly was a great product while it lasted. Unfortunately it didn't last very long =0(
    Ok, just some of these: (1) Since you have mentioned picture disappeared, I assume the sound is ok. If the TV works and you are only not able to see the picture, show a torch light on the screen from a safe distance. If you can see the picture, the backlight of the TV is not getting on and it is a simple problem any good TV technician can fix.
    The sound is fine. Now, pardon my ignorance (lol) but is a torch light the same as a flashlight? I'm picturing flames as you mentioned "a safe distance".
  • Anonymous Aug 04, 2012
    Yes, dear. The torch light is same as a flashlight. We call that way in our country, India. The reason for mentioning safe distance is to keep away static charge near the TV when you handle the flashlight.
  • daniellep417 Aug 07, 2012
    Good morning. To start off, I hope you know that I meant no disrespect. I really wasn't sure what you meant by torch light. Thank you for clarifying that.
    I tried your suggestion but I did not see any picture =0( Is there anything else you can do? I'm really upset to have lost a great TV! =0(
    I just got a "notification" that there was a new message for me but I didn't see one. Did you post anything?
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Aug 01, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292595
Points
3377
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
    Yes, dear. The torch light is same as a flashlight. We call that way in our country, India. The reason for mentioning safe distance to keep away static charge near the TV when you handle the flashlight.
  • Anonymous Aug 10, 2012
    Can someone please tell me or show me a picture of a backlight and tell me where it is located on the 32" HDTV-Ready LCD please? I've taken the back off my TV.
1helpful
Turn on picture and sound are great. for about 60 seconds. then the picture disappear but sound is great. turn power off wait a little bit ( try differ times. from 15 seconds to 10 minutes) Turn back...
The tv have a long board call a LCD inverter board.This long LCD inverter board is dead.That why,the tv have picture only flashes like a min. than,died and have sound left only.The LCD long inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
2helpful
Front panel blocked or locked
RCA Entertainment Series 32" Plus Gold, GEMSTAR, xbox ready has been in the shop twice so far. Transformer replaced and 6 months later the picture suddenly had horizontal white lines that gradually spaced apart more from top to bottom and it had a gray hue and fuzzy, but I still watched it for 3 months that way. Today I turned it on and about a minute later I heard a loud crackling sound coming from the back and the picture disappeared, screen went black. Is it worth fixing again? Please contact me at [email protected]
1helpful
Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Mitsubishi 1995 cs31205 32 inch tv
Good Day;
Sounds like you have the TV in the "close caption " mode (text), turn off. 2. Check batteries and the mode the remote is in; eg TV, VCR, Cable & ect. Good Luck, big IRISH.
1helpful
2answers
Pic problem
Quasar TV SP3232. Picture disappears but comes back by striking the TV . The sound keeps coming. Perhaps something is loose
2answers
No picture
check all resistors right in crt board & resolder picture tube connection. good luck!
Usuable signal/blue screen
No picture, just black screen
Check R3414, an SMD chip on the CRT board. There could be invisible bad solder joints
Noisy picture
Replace relay RY481 on S2 board
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
1helpful
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Top Soyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
