Lexmark E250dn Laser Printer Logo
Posted on Jul 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is the light flashing on the right side - Lexmark E250dn Laser Printer
Anonymous
Level 3:
Genius:
  • Master 1,087 Answers
  • Posted on Aug 24, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1087
Questions
0
Helped
490940
Points
2129
If the light flashing is the "light bulb like button" or the "Ready/Light" button, it means that either the printer is:
• The printer is busy receiving and processing data or printing.
• The printer is printing a directory, font list, menu settings pages, or Print Quality Test Pages.
If it's Busy:
• Wait for the message to clear.
• Press and release Cancel to cancel the print job.
• Press and hold Cancel to reset the printer.
If it's printing a directory, a font list, menu settings pages, or Print Quality Test Pages:
• Wait for the pages to print. The Busy message is displayed as the pages print. The Ready light is on when the
printing stops.
• Press and release Cancel to cancel printing.
My 2005 Mazda MVP has a problem with the right hand side indicators not working.
Only the bulb is linked with those seperate items the bulb runs both blinker and hazard normally one goes both go when u have tufrn signal on inside if u hear it flashing fast its ur bulb
Tail light dim one side ,when right turn on all lights flash
Has to be a grounding issue,look for a chassis ground from the
back harness,pretty weird symptom
2answers
Turn signal will eluminate but not flash. emergancy lights work and flash fine. Have replaced the flasher and turn signal switch.
You know you have 2 flashers right, one for emergency flashers and one for signal lights? Does it refuse to flash on both sides, right and left? Have you checked all bulbs front and back are good?
1helpful
3answers
2004 buick lasabre, right side turn signal blinking fast.
Check the front turn signal bulbs. This will affect the resistance in the circuit and cause the working light to flash at a much faster rate.
In my 88 camaro the low beams dont come on! i can pull the light switch out all the way high beams come on when i get out all the 4 lights on the front of the car work i pull it out just a little bit i get...
ok...silly question, and dont be offended that i asked please, but have you checked the globes...as i have had alot of cusomters coming in with noticing that all the lgiths have blown, but they do not realise until they have none, they dont seem to notice if one goes out ????
Bulbs are good left side flashes right side does not flash front or rear
If lights turn on on right side, just don't flash replace the turn signal flasher, not knowing what type of car you have, most of the time the flasher will plug into the fuse box, silver or black cylinder looking.
2helpful
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Right Turn Signal not flashing.
quick fix,try to run jumper wire from solid lime green wire to tail light green/orange wire Your problem is no power
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
