Cant find how to set number of rings before getting answering machine
After setting the number of rings, press PLAY/STOP to save the setting and exit the menu. Full details are on page 2 of the manual.
SOURCE: change # of ringer on an AT&T 1717 digital answering machine
I don't have a solution, I'm looking for an answer
SOURCE: Answering machine doesn't pick-up reliably
I found in the manual that if the machine doesn't answer after the correct number of rings, then it may be the ringing system used by the phone company. But I have also heard of people with VOIP (such as Vonage) having problems with this as well.
http://telephones.att.com/docMgt/public/art/21714/1738_english_manualpart2.pdf
SOURCE: how to set number of rings
Use Ring Select to choose how many times
the line will ring before the system
answers a call. Set for 2, 4 or Toll Saver.
When you set the system for Toll Saver, it
answers after four rings when you have no
new messages, and after two rings when
you have new messages.
1. Press and hold "set up" for about two
seconds. The system announces the
current ring selection.
2 Press and release "ANNC/SKIP" or "MEMO/REPEAT"
until the system announces your ring
selection.
3 Press and release "Play/Stop" to exit
SOURCE: model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
To check the clock, press CLOCK.
when it gets to number of rings press and hold setup button in, then press skip button to change, I set mine to 5
