Question about Kenmore 24622 Top Load Washer
SOURCE: RE: Putting whirlpool washer back together
I would agree with you, it sounds like it isn't going back together correctly. When I put the cabinets back on them, I first make sure all 4 of the spades sticking up from the base are straight and not bent over. Next I grasp the hole the lid covers towards the front and lift and pull it towards me so the bottom of the cabinet is closer to me than the top. Next, I use my foot to push the bottom of the cabinet under the bar that goes across the base of the machine. Then I tilt the top of the washer back towards the machine. I wiggle the sides, until the cabinet seats into the spades coming from the base. After it seats properly, the clips should be lined up properly to be installed.
Posted on Jul 01, 2008
SOURCE: kemore 92274100 washer
counter weight spring hooks in hole left side of rear spring bracket thens hooks through directly below that in base..unless hole is rusted out then just drill a new one ..by the way some wobble is normal a stationary tub would cause a lot more vibration
Posted on Aug 20, 2008
SOURCE: kenmore top load washer 92573210
4 springs on bottom of washer 3 from tub to top of base hidden, 1 from rear tub to bottom of base straight down, hole in inner lip of base, to counter weight of motor.
Posted on Apr 26, 2009
SOURCE: rubber boot and spring need put back in
Follow these steps:
1. Install the door
bellow (rubber boot) back over the frame of the door opening ensuring you fit it snugly
all the way around the door frame opening.
2. Insert the wire hoop in the rubber groove of the bellow where it fits around the outside perimeter of the door frame. Begin at the top of the door with the wire spring pointing towards the bottom.
3. As you work your way
around the door to the 4 and 8 o'clock positions, you will need to
maintain some constant downward pressure while pulling the spring apart
in order to snap it back into place.
It may be advisable to use a
second set of hands to hold the wire hoop in place while doing this as
it has the tendency to want to come out of the groove.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 19, 2009
