Changed the black and colour cartridges now all the lights on the control panel flash and the printer will not print. I am using windows 7 with the usb cable.
SOURCE: Epson Stylus Photo 1290 InkJet Printer
This is a maintenance request. Basically the internal counter has hit it's limit and now requires that the counter is reset and the ink pads are replaced or cleaned.
Ask at http://www.TheServiceManualShop.com if they do a Rescue Kit for your machine. This should include all the goodies you need to get running again. If they have no kit for machine, let me know as I may have an alternative.
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
SOURCE: All lights flashing on the Epson Stylus photo 870
Unfortunately, the Russian software does not work on a Mac, and it crashes at launch when installed in WZ98 under Virtual PC. However, I found this on another site, and it worked immediately:
The sequence to reset the waste ink counter is as follows:
WASTE INK ROM RESET ONLY 870, 1270
1. Turn the printer off using the power button on the panel of the printer.
2. Disconnect the interface cable at the back of the printer.
3. Hold down the "LOAD/EJECT" and "CLEANING" buttons simultaneously.
4. Turn the printer on. Release all buttons as soon as paper out light flashes.
5. Quickly press (within 3 seconds while PAPER OUT light is flashing) the "CLEANING" button for 10 seconds.
6. Release the button and the printer will initialize.
7. Once initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on
Works great, no muss...no fuss!
SOURCE: Bypass using any colour ink with Epson D120 printer? Possible?
Yup that's Epson for you. I had the same. bought the black one but to get it to work you must have ALL the ink cartridges full. no way around it.
SOURCE: No Windows 7 driver for Epson Stylus Photo 785EPX printer
run windows 7 in virtual xp mode, the printer will function but you will not see the ink levels and I have not found a way to show ink levels. at least we don't have to get a new printer as jay seems to think is the best solution,,,I have yet to find a better printer than this one even with all the new technology. suggest that jay actually think about what he writes before putting it down. just saying a printer is old is definitely not helpful to anyone.
