Question about Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sony bravia xbr has red vertical lines going through it
Posted by Karen Gleason on
Parasuraman S
    Genius:
  • 1,182 Answers
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Posted on Aug 01, 2012
Arian Ramon
    New Friend:
If you press the MENU/HOME button and the lines do not overlap then change the picture settings to "Custom", "Classic", Cinema", Etc... this should get rid of the stripes.. Good Luck!
Posted on Jul 04, 2013
5 Related Answers
Anonymous
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
Wojo64
SOURCE: I have a small green vetical line in my sony
Unplug the TV , the hard reboot will cause the line to disappear in a few minutes, must be some algorithm that kicks in
Posted on Nov 19, 2010
circuitworld
Circuit World
  • 335 Answers
SOURCE: A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Posted on Nov 09, 2009
Anonymous
  • 14 Answers
SOURCE: Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Posted on Feb 17, 2008
Anonymous
  • 8 Answers
SOURCE: how do I remove the stand of the Sony Bravia XBR
you have to lay the tv on it's front on something to protect it from being damaged.on the back you'll see where the base joins the bottom of the display, this needs to be unscrewed and a wall bracket screwed in instead.
Posted on Nov 26, 2009
I have a sony bravia tv which i have had about eight years. four vertical lines have appeared in the bottom right hand area of the screen. one long red line one long green line. and two short lines on...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 18, 2015 | HCDZ General Remote Control Fit For Sony...
Tv picture is pink with vertical lines sony bravia 32 inch XBR
it sounds like a bad t-con board. this board my not be sold without geting the whole screen. the t-con borad is at the top of the screen and connects to your main board
Apr 15, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have a vertical line in the middle of my screen
Call for warenty repair,ur tuner board have problems.Or tries bring it back at were the store u buy it at.Return it exchange for another one.
Mar 23, 2010 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony Bravia KDL-52WL140. We went to bed with working TV and woke up to vertical lines on entire screen with every input. My husband has disconnected all inputs and cables to check for any noise or...
it is fixable, but it depands on the cost, compared to buying a new 1..the problem is with the vertical deflection board....if can get it hope it will work..other options are, reservice the whole unit ..
Oct 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have a bravia xdr9 and it has a vertical red line on the left part of the screen. I don't loose the picture.
The LCD Panel is the source of the problem. Sometimes the T-Con Board that connects to the LCD Panel fails causing this problem. For the most part, the Panels come with this Board and the Board is not available by it's self.
In short, the LCD Panel needs to be replaced.
Due to the cost to replace, I recommend you to call Sony at 1800-222-SONY to see if they would be able to help you in the repair cost.
I hope this helps,
Skyassoc
Aug 25, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Jul 10, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia 46Z4100 has a thin vertical red line on the screen
I assume that when you get the line you lose the picture, if so, you have vertical collapse, either a dry joint in the vertical section or capacitors or vertical I.C., I would doubt that the scan coil would be O/C as that is rare. if you can't do it yourself I suggest taking it to a repairer, as it should be an easy fix...Hope that helps...Phil
May 19, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I have a Sony Bravia KDL-46Z4100 46' I have a green vertical line on left side of screen
this is probly the lcd control module unfortunatley it comes with a new lcd panel
change these.
Mar 10, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
if the line is in the same place all the time im afraid to say that is a pixel problem on your display contact sony they may offer you a replacement display or altleast a way of changing the set.
Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV Logo
3,095 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
