Frigidaire ATF6000ES Front Load Washer Logo
Anonymous Posted on Jul 31, 2012
Washer says no water on most cycles so I'm unable to use the clean washer cycle to get the smell out
  • Anonymous Aug 04, 2012
    The problem was when I tried to run the clean washer cycle it would only run water for maybe 1 minute. It would then beep and display No Water. Come to find out my kids turned the hot water off so that was the issue. So now fixed...thanks though.
  • Official Brand Answer 4,342 Answers
  • Posted on Aug 01, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467821
Points
5907
What exactly is your concern? Are you not getting enough water to start any cycle? Or are you trying to sanitize and clean the unit before a full cycle use?
5 Related Answers
Anonymous
  • 130 Answers
  • Posted on May 07, 2009
SOURCE: crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Anonymous
  • Posted on Jul 20, 2009
SOURCE: cleaned coin trap and now nothing is working.
just fixed mine took off 3 screws on bottom of washer removed panel unscrew round access in front of pump & found clogged debris also took all hose,s off & flushed out this cured the problem i think the clogging was cuased by using wrongt detergent
Anonymous
  • 958 Answers
  • Posted on Sep 20, 2008
SOURCE: Frigidare top loading washer 6 cycle - 10 years old
you may want to inspect the bottom part and see if it still uses fan belt. it could be that the belt is loose and the motor is spinning but can not drive the transmission. so the rubber burning smell is coming from the slipping belt.
the solution is to tighten the belt or replace it if necessary.
tnx 4 using fixya,
drcool
Anonymous
  • 35 Answers
  • Posted on Oct 15, 2009
SOURCE: Frigidaire stacked dryer/washer not draining water
pump is not working check the belt and pump
Testimonial: "thanks!"
Anonymous
  • 2702 Answers
  • Posted on Jun 08, 2010
SOURCE: Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
My Wash smells musty
In most Owner's Guides for front load machines, manufacturer's will advise to keep the door open after almost every cycle to help evaporate the water in the unit. Also to clean the rubber door seal with bleach water. To get rid of the smell there are solutions on the market that you can throw into the tub when you are not washing clothes and run a hot cycle. You can also use bleach, white vinegar and lime juice as an alternative. Then run a hot cycle. Do this about every 2 weeks, and keep your door cracked.
3helpful
Hotpoint Aquarius WD440 Washer/Dryer. After a cycle clothes still smell as if there is stagnant water underlying somewhere yet machine has been looked at - nothing wrong. Still working in excellent order...
You can buy a liquid product (I got ours in Lidl) that flushes out and cleans the machine. If one application doesn't work try it again. It's just like cleaning out the dishwasher. Worked for us and it was really smelling!
2answers
Zanussie essential 1400 smell of mould can't get rid of it
g'day. Move the machine to check for leaking water. This could be from the taps in the back, or hose clamps throughout the machine and could be causing chronic dampness around the machine. Also check for filter to clean pump. You might have to look under the machine. The soap draw can also get clogged up - but generally doesn't smell. good luck
1helpful
My Samsung front load washer, which is about 1 1/2 old, smells like mildew. I've read that people put bleach in the drum and run it on a maintanence cycle and I'm wondering how I do that. ...
I had this problem too---same washer. The rubber door seal often harbours moisture and it's hard to clean just by running a cycle. You'll have to scrub away the mildew by hand.
Get a pair of gloves, a soft sponge, and a bucket of hot water with soap and bleach. Open the door. Press the sponge into the folds of rubber where the moisture is trapped. Work your way around the circumference of the seal. Repeat until the black goo is gone. Finally run a rinse cycle with some bleach.
Avoid this in the future by leaving the door ajar when not in use. Tuck an old towel into the seal to wick away the water.
Let us know if the smell is still there.
2helpful
Hi, there is a really bad smell coming from the machine, also i have just done a 60 cycle and the white wash has come out with black marks on, looks like fungus,
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this.
Hope this helps...please post back for further assistance.
Daniel
4helpful
Lots of mold around rubber gasket; unable to clean off; odor from mold; water in detergent trays; maybe some water leaking from washer; washer bought in 2008
Use a s.o.s pad to remove mold there will still be staining but it will gey the bulk of.Now to get rid of the smell ( this has been a mixture I have used for about ten yers works every time) put the washer on hot heavy wash start when done filling drain what you want to do is make sure the water is the hottest it can be. now start washer again on hot wash when you see water in bottom of tub stop machine to open door ADD two cups of dish washing power( brand does not matter I tell most people to buy cheap stuff at walmart) start machine let it run till you see powder disolve then stop washer and add 1 cup bleach. let unit go through complete cycle..If your washer has a clean cycle use that instead of the heavy or normal cycle. The most I ever had to do this treatment was 2 cycles and it worked every time.Note all front load washers the door must be left open to pervent odor/bellows should be wiped clean after each use/and a good cleaning at least once a month. anyhow if this helped please vote if you need more help please ask
NOTE the dish soap is the stuff for a dish washer
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
2answers
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Smell coming from washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
1helpful
2answers
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
