Question about Nintendo DS Lite Console
My ds lite just switched off and it was charged
My ds lite was charged but it just switched off and wont turn back on when i charge it the charging light turns on but nothing happens at all?
Posted by sophia on
Stony
    New Friend:
  • 17 Answers
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Posted on Jul 31, 2012
5 Related Answers
Anonymous
SOURCE: nintendo ds lite will not turn on, when trying to charge the orange lite blinks once.
after researching this for a while, i heard that it is because the fuses have blown inside the ds. you can try to fix it but it is risky.
good luck!
Posted on Feb 22, 2008
Anonymous
SOURCE: ds lite charging lite comes on but when i press power button nothing happens
i left to go to the mall one day and there were a whole bunch of little kids here and i put mi ds on the back of my sofa and wen i came back my ds didnt come on so i charged it for 3 days strait and on the charge button will come on but when it does it stays on for like 2 minutes then cuts of and mii game doesnt come on and the kid didnt do anything but play with it
Posted on May 24, 2009
Anonymous
  • 23 Answers
SOURCE: NINTENDO DS LITE WON'T CHARGE OR POWER ON
you have to buy a new battery
Posted on Jun 08, 2009
Anonymous
  • 12 Answers
SOURCE: nintendo ds lite won't charge
Sounds like your battery is toast, buy a new one from nintendo, or ebay.
Posted on Aug 15, 2009
glenn_morgan
  • 49 Answers
SOURCE: my DS lite wont charge
Hi, it might be the fuse.
Does the DS turn fail to turn on?
Does the charge light just flash briefly when you plug in charger?
If so it will be the fuse.
If the console it out of warranty, maybe you or someone you know can fix it.
Check out the following youtube videos
Good Luck
http://www.youtube.com/watch?v=io5iN42q3VQ&feature=related
or for an easier but dodgy method
http://www.youtube.com/watch?v=GYWt811XNDs&feature=related
Posted on Feb 10, 2011
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
My ds lite wont turn on. When I switch it on, The screens flash and it turns off again! It still charges, What ddo I do. I dont want to buy a new one!
Try removing the battery and putting it back in. Let it charge fully until the charge indicator goes away and then try again. If you are still having issues, it sounds like the device has become corrupted.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jonathon_2815d94e62f0ea08
Mar 07, 2011 | Nintendo DS Lite Console
Nintedo Ds Wont turn on! Even if Charged!
Does the yellow light come on when charging? Could be that the fuse for the charging circuit has gone, or on of the screens has been damaged. If it's only 4 months old and not been dropped etc, send it back to Nintendo I'd have thought.
May 24, 2010 | Nintendo DS Lite Console
My sond ds lite wont turn on and the charge light
Yes, this problem is normally caused by one or both of the fuses have blown on the logic board.
Feb 17, 2010 | Nintendo DS Lite Console
My DS lite wouldnt switch on whilst i was on it so
It sounds like a faulty on off switch, when you turn it on it is not contacting fully, i had this problem with my grandsons ds lite, what i did was unscrew the ds, then looked to see if the push up and down on off switch was fully contacting when switching on, when i took the case off i could turn it on, i just made sure everything was in place and put the case back on, its ok now, i could be the on off switch had dislodged ater time, and just needed re locating, its nothing to do with getting a new battery.
Oct 15, 2009 | Nintendo DS Lite Console
Each time you charge your battery, the charge capacity is decreased. After a large amount of charges, the capacity is decreased to an amount only enough to turn on a/the screen(s) for a second. Try getting a new battery.
Mar 02, 2009 | Nintendo DS Console
DS Lite wont turn on & wont charge
could be a charger issue try a new charger .
Dec 02, 2008 | Nintendo DS Lite Console
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Nov 27, 2008 | Nintendo DS Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
112 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
