Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
Elly m..
SOURCE: NO SOUND FROM MY APEX GB5108 TV
I had the same problem with mine, it turned out to be a fried audio board. I simply used the audio outputs on the back of the tv to drive a new reciever with surround. Sound a heck of a lot better than the speakers built into the tv.
Posted on Sep 11, 2008
SOURCE: apex 51' gb5108
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and fuzzy images this is a symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Posted on Oct 10, 2008
SOURCE: wavy picture vertically
if you have the speakers on top of the television or a phone near it might becaused by this
Posted on Apr 09, 2009
SOURCE: Hello, I have an Apex GB5108 and it has a
I am not familiar with this particular set, but it sounds like you have no vertical deflection, which would mean your vertical output IC may be bad. The # on those ICs usually start with LA and is mounted to a heatsink.
Posted on Jul 30, 2009
SOURCE: My apex gb5108 convergence lines wont line up.I'm watching 3d
possibly the convergance ics have failed or convergance module
soldercon or both not a very costly repair
Posted on Oct 04, 2009
