Hello, how can I reset the Drum Life of this printer? I know that I need a reset fuse, but its impossible to find a onlineshop for this. Thank you for your help.
SOURCE: How do you reset the OKI c5800 drum?
You don't need to go through all that mess of replacing the fuse. The tone gets everywhere and getting the Drum unit back together with all the gears and shafts lining up is a real pain.
The Drum reset system is very simple. When the printer powers up and runs through its system check, one of the tests energizes the erase LED array built into the Drum unit. The reset fuse routes a small amount of low voltage current off this LED array. There is a contact on the end of the Drum unit that the printer senses. It there is voltage there (ie the fuse is good), the printer resets that Drums counter to 100%. If there is no voltage (ie the fuse is blown), the printer continues on its way.
All you have to do it act like fuse at the instant the printer sends power to the LED array.
There's no soldering, no screws to undo, and no toner all over the place.
The best thing is it takes about 3 minutes start to finish and cost $0.00!
Here's what you need:
• A simple volt/amp meter (an analog one works best, but digital is fine also)
• Two pieces of thin wire about 300mm long. I used old telco wire. With insulation, its about 1mm wide.
• A pair of scissors to strip the wire ends
• X-acto or thin razor knife
1) Strip about 4-5mm off the one end of each wire and 25mm off the other end. Bend the 5mm end at a 90 degree angle right at the base of the stripped part.
2) Pull out the Drum unit (leave the toner cartridge attached to the Drum unit)
3) On the right end of the Drum unit (DU) there are three square brass contacts about 3mm wide. The right end is the end with the blue handle. Looking at the end of the DU, you are interested in the 1st and 2nd contacts from the left (they are the two closest to the screws on a c5800 cartridge)
4) Use the X-acto knife to lift the contact metal and slide the 90 bent end of the wire under the contact. Do this with the other wire on contact #2.
5) Put a little vertical tension on the wires and route them around the blue toner release handle.
6) Gently insert the DU/toner cartridge into the printer. Keep slight tension on the wires until the unit is seated.
7) Wrap the 25mm stripped end of the wires around the volt meter leads. Wrap one so it makes electrical contact, but you could pull it apart instantly at the right time.
8) Set your voltmeter to the lowest amp setting. I put mine on 200micro amps. Also make sure your voltmeter leads are in the correct holes of the voltmeter. You want the amperage or milliAmp holes not the voltage holes. Don't forget to turn the meter on.
9) Get prepared to pull one of the leads off of the one of the thin wires and turn on the printer. Don't be afraid to touch the metal of the wire; the voltage/amperage supplied to the LED array is very low and will not hurt you. A 9 volt flashlight battery is more dangerous.
10) About 10 seconds into the startup routine, you will see you voltmeter display a reading. Instantly pull the leads apart.
Congratulations, you are now officially a 1/16amp fuse.
Your printer will reset the Drum Unit counter and you have another 20K impressions (if the image quality is acceptable to you)
If you have any question, just respond to this post. I'll get the email and answer you.
Good Luck.
Paul
SOURCE: RESET DRUM
Open the front door where you put the toner/drum unit in the machine. Press options then press 1.
Close the door.
Counter reset!
SOURCE: RESETTING FUSER LIFE ON BROTHER HL5140 PRINTER
How to reset the pf-kit message on a brother hl-5140.
SOURCE: drum life near end
Depends on the usage of the machine. If hardly used, you should get a years worth. But here's what you can do:
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly
back in machine, but do no close front cover.
Press Clear/Back
You
will get a message "Replace Drum?"
Select Yes to confirm
SOURCE: How do I reset my drum life once I have inserted a...
Open front cover; hit CLEAR button; hit PLUS (up) button. Close cover. Done.
