Question about Samsung HCL4715W 47" Rear Projection Television
My samsung tv wont turn on. It just keeps clicking but no picture. Did this about a month ago then wen away. Had it on earlier today and picture was fine. It even continues clicking for about 30 sec after I unplug the cord.
Posted by Kevin Price on
5 Related Answers
Anonymous
  • 150 Answers
SOURCE: Samsung 54" rear projection PCL5415R Won't Turn On
Although I am not incredibly familiar with your model, There is most likely a small board mounted above the others near the crts, there is a small red connector with a blue wire if you unhook it it will remove power from the convergence IC's and if they are shorted it might come up with conv out, will need a new module.
Posted on Jul 07, 2007
Anonymous
SOURCE: Samsung LCD TV shut off, wont turn back on...?
My samsung lcd is doing the same thing, and I have been told that the power supply is bad. But apparently samsung won'r sell you one.
Posted on Jul 13, 2008
Ronnie Houston
  • 2920 Answers
SOURCE: Samsung Tantus 52 inch television
have the power supply checked
Posted on Aug 30, 2008
Anonymous
  • 505 Answers
SOURCE: Diagonal lines through the picture.
I've found the lines caused by the digital board before. Unfortunately it is expensive. I'd recommend running it on HD and it will bypass the faulty circuit. The lamp light flashes telling you the lamp is firing up. As the lamp ages, it will take longer and longer until it fails.
Posted on Dec 08, 2008
Nick DelRegno
  • 49 Answers
SOURCE: Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Posted on Jan 24, 2009
We have a e-motion tv we bought it from Aldi about 6 months ago, it's been absolutely fine up until now, earlier on today we switched it on and straight away the input menu kept scrolling down fast on
Check the buttons on the TV are any pressed in and stuck? Try wiggling them if they are. Also check the same on the remote.
If all checks out pull the power out for about a minute. Put it back in again and test.
Jan 20, 2013 | Televison & Video
LNT5265F when first turned on new, small red light came on, played a little tune, then picture came on. About 7 months ago, after the tune played the picture didn't come on, the red light would go...
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board...
If the capacitors is faulty your TV turn on after a lot of attempt until the TV is totally turn on...
In that case you need to replace the bad capacitors on the power supply..
How can you find where is the faulty capacitors? The bad capacitors is usually leak/bulged on top in that case you easily find it through visual check...
Sep 10, 2011 | Samsung Televison & Video
I went to turn on my Samsung a little bit ago, which was working earlier today, and now it won't turn on and is making a clicking noise. The noise does not stop until 10 seconds after I unplug it...
The tv power supply board it got short and already dead some how,tv have clicking noises mean ur tv power supply board are not stable and not regulating high voltages to the rest of the tv other boards.The tv power supply board that the board where the a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
I have an Samsung PS42C451 Plasma 42" TV. I have had it for approximately 10 months. I turned it on today and I have no picture but I still have sound. This has never happened before. I can't even see...
i have a samsung plasma tv ps42c451 bought xmas time about two months ago it decided that it was not going to give me a guide anymore all it does is says no information for everything .
Mar 08, 2011 | Samsung PS42P2S 42 in. Plasma Television
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Tv wont turn on
i have a nlc-3204bc funai hd ready, the stand by light keeps flashing red on and on, can not switch it on
Feb 17, 2008 | Televison & Video
Samsung HCL4715W 47" Rear Projection Television Logo
54 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
