IBM Lenovo IdeaPad Z565 Notebook Logo
Posted on Jul 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F8 key will not work
F8 key will not initate advanced startup options. Advanced options screen blinks quickly and then all moves on to welcome.......
Anonymous
Level 2:
Scholar:
  • Expert 102 Answers
  • Posted on Jul 31, 2012
Anonymous
Expert
Level 2:
Scholar:
Answers
102
Questions
Helped
24221
Points
202
Turn off your laptop, remove the power cable and battery then press the power button for 30 seconds...
wait for 1 min....insert the battery ..power on laptop and then check...
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Acer Aspire 5520G and Nvidia 8400M G. I have tried to install newest drivers from Nvidia official page, but after restarting my windows 8 freezes at home screen.
Booting Into Safe Mode on Windows 8
The trick is to hold the Shift button and mash the F8 key, this will sometimes boot you into the new advanced "recovery mode", where you can choose to see advanced repair options.
You will need to click on the Troubleshoot option.
Now select Advanced Options.
Now choose the Windows Startup Settings option, by the looks of things we were never meant to find Safe Mode.
Finally hit the Restart button.
Like magic, when your PC reboots you will be able to boot into Safe Mode from the familiar looking Advanced Boot Options screen.
select safemode with networking
go to driver site NVIDIA DRIVERS GeForce 335 23 Driver WHQL
32 bit version
for the 64 bit
install in safe mode hope that works
My screen keeps flashing" diagnosing your PC" why
There is a problem with your windows 8 PC's installation, which has stopped it from booting correctly; hence why it starts in 'startup repair', and tries to diagnose your PC. Hold the F8 key while booting your computer to go into the startup menu for Windows; click Advanced startup options; and select Restore my PC; which will reinstall windows.
This may or may not work for your machine, you may have to hold F2, F10, or the Escape key to go into the UEFI setup and go into startup options from there.
Blue screen
Which operating system you are using??
You can follow the given steps to avoid blue screen error..
Start Windows in Safe Mode:
Step1: Turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
Step2: From Advanced Boot Options screen, choose Safe Mode option then press Enter.
Step3: If Windows loads and works fine in Safe Mode, a bad driver is probably causing the error. Uninstall device drivers and reinstall them. If Windows experiences issues in Safe Mode also, repair your hardware.
Startup repair:
Step1: Shut down your computer and then restart it in Safe Mode (see step1).
Step2: From Advanced Boot Options screen, select "Repair Your Computer" and hit Enter. Choose your preferred keyboard layout and then click "Next."
Step1: Click "Startup Repair", and follow the on-screen instruction .Startup repair can solve this problem.
System Repair:
Step1: Follow step1 and step2 from Startup repair section.
Step3: Now select system restore from the System Recovery Options menu. And follow the on-screen instruction to select a restore point.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
How to startup repair my laptop
1.Shut down your computer and then restart it in Safe Mode.To run in safe mode, press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
2.From Advanced Boot Options screen, select "Repair Your Computer" and hit Enter. Choose your preferred keyboard layout and then click "Next."
3. Click "Startup Repair", and follow the on-screen instructions.
How to enter the safe mode with network, which key should i press, please help
Hi chankp,
Welcome to FixYa! How are you doing?
Please try to do the following to boot your pc to safe mode with networking:
  • Turn off the computer. Turn on the computer then immediately start tapping the F8 key repeatedly.
Note:
You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu does not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
  • Use the (Down Arrow) arrow key on the keyboard, scroll down to Safe Mode with Networking then press Enter.
  • Login to your User Name.
Hope that helps. Thank you for using FixYa!
A disk read error occurred Press Ctrl+Alt+Del to restart
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that screen but you end up reaching the Blue/Black screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER
if this fails then try repairing it from recovery console.
  • Insert the OS CD and boot from CD.
  • During Startup, select Recovery Console from the startup options menu.
  • When you are prompted, type the Administrator password.
  • Type the Command chkdsk /r
When I startup my Sony Vaio Netbook, it boots slowly, but never gets to the startup screen. The screen is black with the cursor being the only thing showing (meaning that the screen my be fine). When I...
reboot the system, wait for the VAIO logo to appear, and then start pressing F8(keys depends on the model ) . The Advanced Boot Options screen will appear shortly. Use the arrow keys to highlight the “Repair Your Computer” option and press Enter.
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Operating System Quarantined
Try This:
as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu. Use your arrow keys to move to "Safe Mode" and press your Enter key.
(NOTE): instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu
Once in Safe Mode your screen will be black and your Icon will appear larger then normal.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
