Question about Canon VIXIA HV40 HD HDV Camcorder w/ 10x Optical Zoom BigVALUEInc Accessory Saver 8GB Battery Filter...
My Canon Vixia HV40 won't play dv. It rewinds and fast forwards, but it won't display images for capture on FCP
I've had my Canon for over a year as my device for transferring video onto Final Cut Pro. That is it's only function. It's worked fine until today when I rewinded my dv as usual to prepare for capture and no picture appeared. The timecodes don't display either until you stop the tape and it reveals the number has advanced as if it had been playing normally the whole time. My FCP picks up and recognizes the camera, it's just the camera not displaying any video images. I see the card/charge light is flashing at the bottom, but not sure what that has to do with anything since it is always plugged in. Any advice? Any experience with this?
Posted by Tamara Thomas on
Bob Buchholz
    Scholar:
  • 136 Answers
I agree that dirty heads are the most likely cause. Purchase a mini-DV Head Cleaning Cassette and follow directions.
Posted on May 01, 2017
David Steeves
    New Friend:
  • 57 Answers
Dirty heads, get a dummy cassette cleaner
Posted on Apr 27, 2017
5 Related Answers
Anonymous
  • 883 Answers
SOURCE: Eating Tape when rewinding in vcr mode
look for a tiny pinhole and insert a pin while powered up to reset the device. if no-go, then the take-up reel needs attention...needs possibly a new or well-cleaned-with-alcohol-swab rubber belt
Posted on May 27, 2007
t00nz
CameraR
  • 4738 Answers
SOURCE: Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Posted on Apr 27, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Tape Playback
Try cleaning the tape heads with a DV tape cleaner and see if that works.
Posted on Jul 07, 2008
Anonymous
  • 5 Answers
SOURCE: Horizontal lines on display but firewire and SD card work fine
Hello people who face similar problems...
First confirm whether it is a problem with the head assembly/ dirty heads.
Do the symptoms appear only on the camcorder's internal TFT side display or is it visible on an external monitor (connect using the AV cable supplied) and the EVF(electronic view finder) also.
If it is visible on the EVF, TFT Side display and the external monitor then it is definately a case of Bad video heads or the tape guide requires to be aligned or calibrated
Posted on Aug 26, 2008
Anonymous
  • 4 Answers
SOURCE: Capture video from Canon Vixia stopped working with iMovie
Video files come from Canon Vixia hg20 are in AVCHD format and this is a format which is difficult to be imported and edited by FCP and iMovie. So you have to convert AVCHD files to other easily edited video format, like FCP and iMovie preferred MOV format.
As for AVCHD Converter, have a try Aunsoft MTS Converter for Mac which is is a powerful video converter, player, editor for Mac and Windows. It can play many various movie files; it can encode movies to many formats, including iPod; it can cut, trim and join movies.
You can use this program to open and play most movie formats transport streams; edit them with crop and Trim;export them to QuickTime, AVI, DV and MPEG-4 files with more than professional quality, so you can easily import them in a DVD authoring tool, and use them with many other applications or devices.
http://www.aunsoft.com/mts-converter-mac/
Posted on Nov 01, 2010
I am trying to digitize HDV footage using fcp 6.0.6 on an Intel imac with 2gb ram. Trying desperately to get my computer to recognize the Vixia HV 30 camera, but it will not. I have tried changing...
First, confirm what type of video is being output from the camera as HDV cameras can also ouput DV or can Downconvert HDV footage form the camera to DV even if the settings for recording were HDV.
The message is to double check and understand the menu settings within the camera.
Once done FCP will require an Easy Setup that matches the camera output.
If you shot and are indeed outputting HDV, start off with Easy Setup>HDV-Apple Intermediate Codec1080i60, assuming you a an NTSC user.
tip
Convert Canon VIXIA HF S21/HF S200/HF20 AVCHD MTS/M2TS Files to iPad
Canon Vixia HF camcorders are becoming more and more popular among people who want to capture movies and movies of their daily life and interesting moments. Most Canon Vixia HF series Camcorders store video in AVCHD .mts file format that is a high definition video format. Take Canon Vixia HF S21 as an example, Canon HF S21 stores video in AVCHD MTS file format with MPEG-4, AVC/H.264 as video codec, and the 64GB internal flash drive enables long time video recording for more than 8 hours with Full HD 1920x1080 recording at FXP profile. It enables double slots for SD memory cards. (Some of Canon HF series and Canon VIXIA HF series camcorders are compatible with Mac, see at iMovie '09: Camcorder Support )<br /> iPad, as the newest tablet computer of Apple, offers you the best way to experience the web, email, photos, and video. However, if you want to enjoy videos shot by Canon Vixia Camcorder on iPad, maybe a little difficult for you to directly import Canon VIXIA AVCHD mts files to iPad, for iPad supported video formats are H.264, MP4, MOV. So you need to transfer Canon Vixia HF video files to MOV, MP4 or H.264 for iPad firstly, then you can import converted AVCHD MTS files to iPad and play them on iPad. <br /> Doremisoft Mac Canon VIXIA HF to iPad Converter is the best software to convert Canon VIXIA AVCHD MTS/M2TS to iPad MOV/H.264/MPEG-4, etc. It also can transfer AVCHD camcorder and camera video to other popular video formats including AVI, WMV, M4V, 3GP, 3G2, MPG, SWF, FLV, DV, MPEG-1, MPEG-2, MKV, H.264/MPEG-4 AVC, MPEG-1, MPEG-2, MPEG-4, MP4-Xvid, etc in order that you can import these AVCHD MTS/M2TS files to iMovie, FCP, FCE, iDVD, iPhone, Apple TV, iPod, PSP, BlackBerry, etc. <br /> Now, tutorial for you to convert Canon VIXIA HF AVCHD MTS files to iPad step by step as follows:<br /> Step1: Install and Launch Doremisoft AVCHD Converter for Mac<br /> Step2: Add Canon VIXIA HF Video Files<br />Click "Add File" to upload Canon VIXIA AVCHD MTS/M2TS files to Mac AVCHD Video Converter. You can add several videos one time.<br /> Step3: Select Output Video Format for iPad<br />Click "Profile" to open the Profile drop-up list to choose MOV, MPEG-4 or H.264 for iPad on Mac. And you also can set output video format for Mac, iMovie, Quicktime, iDVD, iPod, iPhone, etc.<br /> Step4: Convert Canon VIXIA HF AVCHD MTS/M2TS for iPad<br />Click "Start" to convert Canon VIXIA HF AVCHD video to MOV, H.264 or MPEG-4 for iPad. After conversion finished, you can watch and share converted Canon VIXIA HF videos on iPad.<br /> Related: How to Convert and Import Canon VIXIA AVCHD MTS/M2TS Files to FCP for Editing?<br />How to Convert and Edit Canon VIXIA HF series to iMovie?
on Nov 19, 2010 • Computers & Internet
tip
Import Canon VIXIA Series Video to FCP and Edit Canon VIXIA HF Video in FCP
Most Canon VIXIA HF series and other VIXIA series camcorders record video in high definition using a special codec (compression/decompression) called AVCHD, for example, Canon VIXIA HF11, VIXIA HF R11, VIXIA HF200, VIXIA HF R100, etc store videos in HD format using AVCHD compression and the files have MTS extension. For Mac users, it's virtually impossible to edit Canon VIXIA AVCHD footage natively in FCP due to different video codec and taking large space.
But also some of Canon VIXIA HF series camcorders can support iMovie' 09 or iMovie' 11. You can check the list of Canon VIXIA HF camcorders compatible with iMovie' 09 as follows:
Canon VIXIA HF M30, VIXIA HF M300, VIXIA HF R100, VIXIA HF R11, VIXIA HF S20, VIXIA HF S21, VIXIA HF S200
So if you would like to edit Canon VIXIA AVCHD video in FCP, you need to convert these AVCHD MTS files to FCP supported video format like MOV, MP4, DV, then you can import them to FCP for editing.
Doremisoft Canon VIXIA to FCP Converter is specially designed for Mac users to convert camcorder video like Canon VIXIA video, Sony HDR video, Panasonic HDC video, etc to Final Cut Pro MOV/MP4/DV. It also supports converting video including MTS/M2TS/TS/TRP(AVHD H.264, VC-1, MPEG-2 HD), MKV, etc to MOV, MP4, AVI, M4V, 3GP, 3G2, MPG, DV, MPEG-1, MPEG-2, WMV, etc.
Doremisoft Mac AVCHD Converter not only have the ability to convert HD videos to SD (Standard Definition) format, but also the ability to convert SD to HD which contains MPEG2-HD, MPEG4-HD, H.264-HD and more. More editing functions of Canon VIXIA to FCP Converter you can see edit AVCHD MTS/M2TS Files on Mac OS.
Before you import Canon VIXIA videos to FCP to edit them, the following easy guide can help you convert Canon VIXIA AVCHD MTS/M2TS files to MOV, DV or MP4 for FCP.
Step1: Add Canon VIXIA Video Files
Click "Add File" to upload your chosen Canon AVCHD MTS, M2TS files to Canon VIXIA to FCP Converter after you lauched it.
Step2: Set Output Video Format for FCP
Click "Profile" to open the Profile drop-up list to select MOV, MPEG-4 or DV as output video format for FCP on Mac OS. And you also can convert Canon VIXIA MTS files to iMovie, Quicktime, iDVD, iPod, iPhone, etc.
Step3: Convert Canon VIXIA Video to FCP
Click "Start" to convert Canon VIXIA videos to FCP, and you can edit your these converted AVCHD files with FCP on Mac OS X after converting finished.
Related: How to convert AVCHD(MTS,M2TS) to DV on Mac?
How to Convert and Edit Canon VIXIA HF200, VIXIA HF R11, VIXIA HV30 Video to iMovie?
on Nov 17, 2010 • Computers & Internet
1helpful
2answers
Tdk sony dvm60 miniDV tape not playing in final
HI please check your easy setup in tyhe fcp and set it as pal or ntse dv and should get the video in
tip
Convert and Edit Canon VIXIA HF200/HV30/HF R11 to iMovie, iMovie? 09, iMovie? 11
"Vixia HV30 HDV camera help! Mac and iMovie? I cant get my vixia HD30 HDV canon camera to import any video to my iMovie. ive set the video type to HD-1080i-30 but still nothing. any ideas on how to fix this?"
"I cannot get my mac to recognize my new Canon Vixia hf200 video camera. How do I get it to import my videos? I have a mac tiger, 10.4. My imovie is '07. The Canon is HD and connects through USB."
As Canon VIXIA HF series camcorders becoming more and more popular among people, you may have problem of uploading Canon VIXIA HF video to iMovie, or Mac. Because some of Canon VIXIA camcorders cannot be compatible with iMovie, iMovie' 08, iMovie' 09, such as Canon VIXIA HF200, VIXIA HV30, VIXIA HFS100, etc. Or even though Canon VIXIA camcorders can be compatible with iMovie or Mac, but sometimes video off Canon VIXIA series is not recognized by iMovie due to different aspect ratio or video codec.
If you cannot import Canon VIXIA video like Canon VIXIA HV30, VIXIA HF200, VIXIA HF S100, etc to iMovie for editing, you need a powerful Canon VIXIA to iMovie Converter to convert Canon VIXIA AVCHD video to MOV, MP4, DV for iMovie firstly, then you can import them to iMovie to share or edit.
Doremisoft Canon VIXIA to iMovie Converter is designed for Mac users to convert camcorder video like AVCHD MTS/M2TS to MOV, MP4, DV for iMovie and Mac. It also support converting video such as MOD, TOD, MKV, etc to Mac, iPad, iPod, iPhone, PSP, Blackberry, iDVD , FCP, FCE, etc.
But how to transfer Canon VIXIA video to iMovie? Here, quick guide for you to follow to convert Canon AVCHD MTS, M2TS files to iMovie step by step:
Step2: Import Canon VIXIA Video
Click "Add File" to input your Canon VIXIA AVCHD MTS files to Mac AVCHD Video Converter. You can upload several videos one time.
Step3: Set Output Video Format for iMovie
Click "Profile" to open the Profile drop-up list to select MOV, MP4 or DV as output video format for iMovie.
Step4: Convert Canon VIXIA Video to iMovie
Click "Start" button to convert Canon VIXIA AVCHD files to iMovie. After conversion finished, you can edit your converted Canon VIXIA videos with iMovie as you like.
Related: How to Get AVCHD MTS/M2TS, MOD Files off HD Camcorder to Mac, iMovie, FCP?
How to Convert and Import Sony HDR Series Video to Mac, iMovie?
on Nov 09, 2010 • Computers & Internet
tip
Convert/Import MTS, M2TS files to FCP MOV, MP4, DV on Mac OS
MTS format is high-definition MPEG, AVC, H.264 transport stream video file format which commonly used by HD camcorders such as Sony, Canon, Panasonic, JVC. HD camcorder makes use of MTS in the form of AVCHD, a format for recording and playback of high definition video.
Nowadays, most digital camcorders record videos in AVCHD MTS/M2TS format that is a high-definition and high quality video format.
Here you can check the list of some popular HD camcorders recording video in AVCHD MTS/M2TS format including Canon, Sony, Panasonic and JVC as follows:
Canon HF10, HF100, VIXIA HF S100, VIXIA HG21, VIXIA HF200, VIXIA HF S200, VIXIA HF M300, HG20, HG21, IVIS HF M31, IVIS HF R10
Sony HDR-SR1, HDR-SR10, HDR-XR100, SDR-SR10, HDR-SR11, HDR-XR100, HDR XR-500V, HDR-TG1, HDR-CX7, HDR-SR5, HDR-CX7
Panasonic HDC-SD60, HDC-SD100, HDC-SD200, HDC-HS100, HDC-HS350, HDC-HS700, HDC-TM35, HDC-TM350, HDC-TM700, HDR XR-500V
JVC GZ-HD10KR, GZ-HD30, GZ-HD40, GZ-HM200, Everio HD10, Everio GZ-MG130
HD camcorder owners can enjoy HD video with their HD camcorder, however, original AVCHD MTS, M2TS files cannot be directly imported to Mac. So for Mac users, if you want to import MTS/M2TS video to FCP(a highly-regarded video editing, compositing, and special effects package for the Macintosh) on Mac for editing, you have to convert MTS/M2TS files to MOV, MPEG-4, DV for FCP firstly.
Doremisoft MTS to FCP Converter for Mac is the best software to convert original MTS, M2TS files to Final Cut Pro with good quality. It can transfer MTS video to MOV, MP4, M4V, AVI, DV, 3GP, etc and other HD videos like HD MP4, HD MOV, etc. With this AVCHD Converter for Mac, you can convert MTS video to FCP, FCE, iMovie, Quicktime, iTunes, iDVD, iPad, iPod, iPhone, Blackberry, PSP and so on.
Easy Tutorial for you to convert MTS/M2TS files to FCP on Mac here:
Step1: Import MTS, M2TS Files to Mac MTS Converter
Click the "Add File" to upload your chosen AVCHD MTS, M2TS files to MTS to FCP Converter for Mac after you lauched it.
Click "Profile" to open the Profile drop-up list to select MOV, MPEG-4, or DV as output video format for FCP on Mac OS. And you also can convert MTS files to iMovie, Quicktime, iDVD, iPod, iPhone, PS3, Blackberry, etc.
Step3: Convert MTS Files to FCP
Click "Start" to convert AVCHD MTS, M2TS videos to FCP on Mac. you can edit your converted MTS, M2TS files with FCP on Mac OS X after converting finished.
Related: How to Convert MTS, M2TS to iMovie for Editing?
How to Convert Panasonic HDC Series to Mac and Edit Panasonic HDC Video in iMovie, FCP?
on Oct 21, 2010 • Computers & Internet
2helpful
(Canon HV-30) Firewire not responding any more with Final Cut Pro
SET YOU CAMERA TO FIREWIRE OUT, NOT AUTOMATIC!! <!-- from fixya rte -->
Canon hv 40 cannot import video to the computer
have tried everything - every combination of settings - my hv 40 and windows 7 and 4 diffrent programs can not capture hd video - will capture dv - can control camera from computer in hd mode but no program will switch to hd capture mode so if you find an answer please let me know
Please help me...When I connect my canon xh a1 to FCP 6.0 it says Unable to Initialize Capture Device Device is not connected or the capture preset is not setup correctly. You may still log offline...
Try playing the tape before connecting up to the mac with the firewire and before loading FCP up. Usually fixes it for me when using either iMovie to import or FCP
Canon VIXIA HV40 HD HDV Camcorder w/ 10x Optical Zoom BigVALUEInc Accessory Saver 8GB Battery Filter... Logo
Top Canon Cameras Experts
old marine
old marine
Steven Wander
Steven Wander
nexrad_chris
Are you a Canon Camera Expert? Answer questions, earn points and help others
