Question about Rival VS230 Seal A Meal Vacuum Food Sealer
When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
Seal-a-meal. Model #vs110 vacuum sealer
Posted by Holly Music on
  • pdarrach
    pdarrach Oct 02, 2012
    http://www.ebay.com/itm/NEW-PTFE-Teflon-... should take you to the tape source.
  • Anonymous Mar 13, 2014
    light for sealing does not come on nor does the hands free light come on. when pressure is released o corners motor stops and heat strip has not sealed bag.
pdarrach
    New Friend:
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Posted on Oct 02, 2012
2 Related Answers
Anonymous
SOURCE: Had a Rival VS110 Seal-a-meal vacume good sealer
you have to push down with a lot of force to get the rubber seal to give enough to allow it to latch...
Posted on Nov 28, 2010
GetMeOttaHere
  • 2926 Answers
SOURCE: Hi I have a RIVAL
Bag will not seal
• Check that there aren't any gaps, folds, wrinkles or holes in pre-sealed edges.
• Moisture of foods with high liquid content will prevent the bag from
sealing properly. Cut bag open and wipe top inside of bag and reseal.
• Make sure you've placed the bag in the proper place. When making a
bag from a roll, make sure end of cut piece is on Sealing Strip, NOT over
Lower Sealing Gasket or in Drip Tray.
• Make sure you give the appliance time to cool down. Wait at least 20
seconds between seals.
If all the above have been verified and the machine will still not pull a vacuum, you will need to replace the upper and lower gaskets.
Posted on Dec 22, 2010
V3840 heat strip doesn't get hot
Could be the heating element (wire that gets hot enough to melt plastic) is going bad, how long have you been sealing bags with the unit? If you have used it for some time there is the possibility of build up plastic/residue on the the wire or the surface that actually comes in contact with the bag as I would suspect there is a coated surface the element heats up as opposed to the element / wire coming in contact with the plastic itself!
Nov 19, 2017 | FoodSaver Vacuum Food Sealer - V3840
Tip
PERMANENT OR TEMPORARY FIX OF REFIRDGERATOR FREEZER DOOR SEAL!!
I picked up a used RV fridge once and the seal around the door had weakened and stayed pulled out and away from the door metal.
There is generally a long strip of magnate inside the seal that helps the door to weld its self closed to prevent outside air from entering.
I was irritated with this because once they do not seal well then the fridge/freezer has a tendency to run more often, not to mention allow moister inside which of course causes freezer burn and ice build up and a higher temperature in the fridge and freezer.
So one day I was looking at it and one of those huge light bulbs appeared over my head.
I went and borrowed my ladies hair dryer and grabbed a pair of pliers.
By holding the seal in the damaged spot and pulling with some force, (But not too much force), and pointing the dryer on the high setting at the pulled out area it will heat the seal up and make it very soft. While holding it and the more it softens let off the pressure a little as to not allow the seal to tear on you. The plastic over the magnates get pretty soft.
After holding it out for a minute or so then move the dryer away but continue you hold the seal pulled out until it cools down. Release the seal once cool and test the door closed.
You may have to do this in several inches of the bad area and you may need to do it several times but with a little patience this will work.
It beats the hell out of having to fight with and replace the hole new seal.
Be sure to clean the seal on the magnate side and the metal it sticks to with some steel wool or a good stiff scouring pad to insure the best seal to take place.
on Apr 22, 2010 | Refrigerators
Seal-a-Meal seal has blister on it
I think that you have the same problem that I have. The protective tape over the heating element [a strip in my case] has a hole in it and allows the element to come in direct contact with the bag. Also, the heating strip had a kink in it was was no longer flat. I carefully cleaned the heating strip and flattened it out as best I can. I have ordered some tape from : http://www.ebay.com/itm/170848027703?item=170848027703&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr to replace the defective one. A simple job.
Jul 17, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Kohler toilet.............flapper leaking, so replaced it............in trying for better seal, put gallon plastic bag around hand and tried to push down flapper for better seal......Whoosh.......lost...
Hi lip58122
Get a piece of wire a couple of feet long (straightened metal coat hanger) and make a small hook in the end, insert the wire hook into the flapper hole and turn the wire a few times in a circle...you are trying to wrap the bag around the hook, if sucessful you will be able to remove the plastic bag.
Please take time to rate me
Sep 06, 2011 | Kohler K-3451 Memoirs Comfort Height...
My 1984 corvette crossfire v8 smokes wnen stated a puf of white smoke sometimes just a little sometimes a lot but runs great
it could be a lite blue colour that looks white,if so then the car is burning a little oil,the valve seals are probably dried out and allowing small amounts of oil to be drawn into the combustion chamber past the seal and valve guides when the car sits and when started up the oil gets burned in the combustion chamber.if its white smoke then it could be a small head gasket coolant leak.
Jun 20, 2011 | 1984 Chevrolet Corvette
I need to put on my cylynder head gasket seal and my vehicle is blowing out white smoke.is my problem my seal or something else?
in general when car smokes ( white ) it burns the engine lubricating oil this because the sealing rings ( triple for each piston ) not doing their job any more or for another reason the cylinder wall itself due to the continuous friction between wall and seal o rings it creates a very Little gap that allows the oil to enter the combustion chamber and mixed then burned with fuel generating that white smoke and decreasing engine pressure
you will have to replace the cylinder head gasket since you are going to reveal the head to get into the pistons seal o rings
if the cylinder walls got little wider due to friction don`t panic you will get lager seal o rings to skip such a problem
May 30, 2011 | Chevrolet Suburban 1500 Cars & Trucks
I have white smoke coming from the tail pipe of my 1996 Cadillac DeVille. Not a blown head gasket, no water in the oil. Could it be my pistons or just needing new seal. Am I burning oil or have an oil leak...
hi... it all depends on the colour of the smoke... usualy blueish smoke will mean it is oil burning and your piston rings may be getting worn if it is black then it might be running too rich etc.. a little bit of water is fine infact usualy it is a good sign that your engine is not running rich or lean so it is pointing towards oil seals... also if it was running rich it would probably do it more when it was cold
Feb 11, 2010 | 1996 Cadillac DeVille
Right door pops ajar open when left side is shut
you need to replace the seal on that side of the door due to it being worn. The easiest way to replace the seal is to lift the seal up from the inside and you can see the little bolts (1/4 inch head) on the inside. These bolts run through a metal strip that in turn holds the seal down. Once you loosen (do not remove) these bolts you can pull slightly and the seal will come out from the metal flashing strip holding it down. Look at the seal and you will notice a small hump where it sat on the inside of the hump on the metal flashing when you see it you'll understand what I mean. Once the older seal is removed the new seal is ready for replacement. Hint: If you let the new seal sit out in the sun for an hour or so it will become soft and pliable and much easier to work with.
Reinstallation is just the opposite of removal.
To make sure you get the correct seal take the model and serial numbers to a appliance parts house and they should have one for replacement.
Good Luck on your repairs hope this helped
Dave
Sep 02, 2009 | Maytag MFC2061HE Bottom Freezer French...
Clothes getting stuck in door seal when drying.
the plastic that you see overlapping the metal on the sides of the opening is in two parts, top and bottom, you can see the seem. the top is the smaller part, this plastic is also the drum support on the front. There are some glides on the top section that wear with time, after a few years they may need replacement. Perhaps these are worn out dropping the drum creating an uneven gap and catching. there is also a felt strip in there between the front of the dryer and the drum, keeping it back.
To view this remove the top by removing the 2 screws inside upper door opening holding top down. then lift top and if plastic console slide to left then pull away, metal -just pull straight. remove 2 screws holding front to cabinet sides. pull front forward. glides are visible on top. if not there or worn thru plastic replace upper plastic support
May 05, 2009 | GE DBXR463EDWW Electric Dryer
Foodsaver compact vac 550 sealing strip doesn't seal
My machine stopped working because the sealing ribbon was broken and the tape was worn. FoodSaver no longer does repairs. I knew the wire was called nichcome ribbon so I searched that. I checked the resistance of the ribbon on my machine, it was about 3.8 ohms. I found a site called mpakonline.com and from their site I bought 1/16 x .005 nichrome ribbon and 3/8 x 5 MIL. x 18 YD Acrylic Teflon Tape. The total cost of these items was about $36.00, the ohm value of their ribbon was 1.66 somewhat less.I used ends from radio shack made the repair and it has been working fine for the last two months and I have enough material leftover for about ten more repairs.
Nov 14, 2008 | Heating & Cooling
Rival VS230 Seal A Meal Vacuum Food Sealer Logo
1,146 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Colin Stickland
Colin Stickland
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
