Furniture Logo
Anonymous Posted on Jul 30, 2012
What's the difference in sizes between hard-sized and soft-sized water beds?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Jul 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
16
Questions
8
Helped
3696
Points
49
Hard-d are larger of the two and come inthree different s: California King, California Queen, and Super Singles. Soft-d water beds come in standard s. Also, hard-d waterbeds are longer (84 in), while soft-d water beds are between 75-80 inches.On the other hand, soft-d beds are wider.
What are the sheet dimensions of a kingsized bed?
I checked on Wikipedia and funnily enough, different countries have different sizes for what they call a "king" bed.
Check out the size chart here.
Jul 11, 2013 • Home
1helpful
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
What sizes do donut beds come in?
Donut beds come in different s, depending on your dog's . Donut beds also come in two different shapes: oval and round.
Aug 29, 2012 • Anima Dogs
What sizes do hard-sided water beds come in?
Unlike soft-sided water beds that come instandard s, hard-sided water beds come only in California King, CaliforniaQueen, and Super Single s.
Jul 30, 2012 • Furniture
2answers
What sized beds are typically found in hotel rooms?
In hotel rooms, you usually have the option ofchoosing between queen and king d bed as the main bed in the room.
How many gallons of water does a waterbed hold?
This obviously depends on the size of your waterbed. My queen sized bed hold around 185 gallons. I checked online for you about a king sized bed and they generally hold around 250 gallons of water. Hope this helps.
Jul 24, 2012 • Furniture
3answers
What's the size of the common mattress?
A children mattress is mainly between 38 on 75 inches.
An adult single mattress is around 53 on 75 inches.
A couple king size mattress is around 76 on 80 inches.
Jul 18, 2012 • Furniture
FUJI XEROX CM205fw can't set custom paper size
So I am not the only one encountering the same problem! Printing A4 & DL are great but it simply does not let me print A6 properly no matter how hard I tried to configure the paper size (at the printer settings, printer preferences, the application settings etc)
Can Fuji Xerox fix this?
Top Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Furniture Expert? Answer questions, earn points and help others
