Digital Mind Corporation iQ Sound SC-PMP2225 MP3 Player Logo
Question about Digital Mind Corporation iQ Sound SC-PMP2225 MP3 Player
I need to know how to store music onto my mp4player mp3 touch screen 2.8" camera+web cam 4gb
Not sure what is needed, a sb card or memory card and what is the purpose of this card?
Posted by whiti taitua on
Jonathan Poston
    New Friend:
  • 75 Answers
Well actually you would a sd card to store music onto a device and a sd card is a type of memory card
Posted on May 14, 2014
How do I put apps onto my Eclipse T2810C mp3?
Can you access Google play store? You should find an app to suit you there.
2helpful
Is ATI Radeon HD 4250 Graphics an OpenCL graphics card compatible with FInal Cut Pro X?
As "Final Cut Pro X" is an Apple program, you need to make sure you are using an "Apple" Operating System. It will not run on Windows.
Hello my camera doesnt accept hp 4gb sdhc card.when i placed card in, it says card error.... Also,i cant format when sd card is in and ''card error'' on screen...(my sd cards are brand new) plese give...
Okay we have a problem, to properly answer this question "we" collectively need to know what make and model the camera is. However one clue to your problem was that you said SDHC and 4gb.
I'm going to give you a diagram on the SD card type lock make sure it's in the correct position (not locked) Also the SDHC is a newer style memory card and 4 gig is a ton of memory for point and shoot cameras.
If the card lock thing doesn't work and you still can't format then I'm going to say that your camera can't handle the memory capacity of the 4gig SDHC memory card.
Don't panic yet, you may be able to go onto the camera manufactorers web site sift through the models and find the firmware updates for your camera. Updating to new firmware editions could open the possibilities of using a larger card.
Here is the diagram hope this is all that is needed.
Diagram
Jan 05, 2011 • Cameras
My phone won't sync any music onto my 4gb memory card.
When u insert a memory card you have to reboot your phone. Hope 4gb memory is not too big for your phone? If not check the memory card seat and clean it and insert the memory card again. Thanks
I need to know how to download music onto my Ka08 mini but the instructions manual is in really bad english. Could you help me on how to do it?
1. Make sure you have a microSD card inserted in the phone(the phone itself doesn't have enough memory)
2. plug the phone into your pc and wait for the pc to recognize it
3. drop MP3 files to the microSD card into the folder named music or MP3 (create one if it isn't there)
2answers
I have a 512MB sandisk memory card for my sprint
Take the SD card out of the phone, if the card is micro sd you may need to put the card in the adapter that usually comes with it. Next, insert it in the computer's memory card reader, then drag and drop you files and music onto the card. If you see a folder labled MUSIC, thats where the music would go, just match up the names.
2answers
Sansa e-series won't read data/video off flash
did you record it using the provided converter ? also try and see if you copy it to the player itself if that works if it does then its most likely your sd card
1helpful
2answers
How to copy mp3 from pc to the memorycard in my phone.
Better buy a card reader and copy in the memory card and the insert the card and enjoy music. This phone especially has a problem of "no good access" to memory card along with phone and also with phone.
Card reader/writer is the best option
1helpful
6answers
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
4helpful
21answers
Motorola i880 MP3 player
Very Simple Solution. I have the same phone.
First you need a Data Cable that connects your phone to a USB port on your PC.
Secondly, go to http://idenphones.motorola.com/iden/support/software/html/mp3_software.html
and download the mp3 loader.
Its very easy to use. good luck.
btw, I found a data cable on ebay for $5
Top Digital Mind Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Digital Mind Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
