SOURCE: dissconected line
just had the same problem. it turned to be the large black cable that goes from the control box to the head unit. hope that helps.
SOURCE: kenwood ddx8017 stereo
NEED MORE INFO DO YOU HAVE AN IPOD CABLE ATTACHED OR A SATELLITE RADIO ATTACHED HAVE SEEN THIS PROBLEM WHEN CABLES FOR THESE OTHER COMPONENTS ARE THERE BUT NOT THE DEVICE ITSELF. LET ME KNOW WHAT ALL IS ATTACHED.
SOURCE: error message
Hi the wiring is not fit to your unit! please check one by one to see its fit
Thanks!
SOURCE: kenwood kvt817 dvd player says
The unit needs a hide-away brain connected via the big black data cable to make it work to work. Because all your speaker outputs and connections is through the brain. If you don't have the brain, data cable connection is loose or a mal-function hide-away brain then you will get that message on the black screen only. You can buy the brain on eBay or search it up on google if you need one. Hope this will help.
