Question about Whirlpool LSQ9610L Top Load Washer
Washer sometimes spins slow
Sometimes washer spins correctly, sometimes too slow and all of the water does not spin out.
5 Related Answers
Anonymous
SOURCE: Washer spin cylcle leaves clothes wet
Mine did the same thing. Solution. I took it back to the store where I got it. Fortunate for me they gave me my money back. Now I am looking for another one. What a nightmare. There is nothing that has a consistently good recommendation except Miele. Where I live they are not available. Well!! We could always go back to the scrub board. je
Posted on Sep 13, 2007
Anonymous
  • 261 Answers
SOURCE: washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Posted on Oct 16, 2008
Shopguy
  • 13 Answers
SOURCE: washer will not high spin
It sounds like a set of clutches would fix it. If not clutches...transmission. :(
Posted on Feb 27, 2009
Anonymous
  • 6 Answers
SOURCE: washer does not spin clothes - only slowly or not at all
I resolved the same problem yesterday. Funny, it did not cost a penny to fix. After moving the machine away from the wall I noticed two screws that were laying there and after removing the body of the machine found that only 1 of the 3 screws that were holding the housing (for what I assume was the transmission or belt drive) was still in place. I screwed in the 2 screws and it worked fine again.
Posted on Apr 27, 2009
Anonymous
  • 3741 Answers
SOURCE: Washer won't spin properly.
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 05, 2009
Why slow spinning?
a slow spin sometimes indicates that a out of balance switch might be malfunctioning
Oct 17, 2015 | Maytag MAH6700AWW Neptune Front-Load...
Ge washer WJSR4160DAWW will not spin will agatate
FIRST IS ALL THE WATER BEING PUMPED OUT? SOMETIMES IF IT IS NOT THE SPIN WILL BE SLOW. ALSO CHECK BY LOOKING IN THE BACK OF WASHER THAT NOTHING IS CAUSING A DRAG ON THE TUB. CHECK THAT THE BELT IS NOT LOOSE AND SLIPPING.
May 06, 2014 | GE WJSR4160DWW Top Load Washer
Washer drains but sometimes doesn't always spin. Seems to really hate heavy loads like towels. Sometimes a small amount of water is still in the bottom of the tub after the spin cycle has failed. I reset...
Depending what unit u have most don't have belts now days the have direct drive couplers or single unit motors which act as motor and transmission all in one but more to ur point sounds like ur motor is getting week and needs replaced
Dec 05, 2017 | GE Profile WPRE6100G Top Load Washer
Amana ALW880QAW doesn't spin and agitation is slow
winephan,
I could be the pump slowly ceazing causing the belt to slip which would give a burning smell.
Motors in those units, are well build...have a service guy in but DON"t say anything about the motor.. because they will say it because you mentioned it
I sounds like you pump
Jul 22, 2010 | Amana ALW880WH Top Load Washer
I have a Sears Kenmore washer that sometimes does not spin in the spin cycle and sometimes it does. The timer progresses to stop, but clothes are still dripping wet. Resetting timer from spin usually...
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Error codes "f1" "f22" etc. and washer stops at different times
Replace water inlet valve or clean water inlet screens. Remove the water inlet hoses and take a look see. Just guessing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Spin speed slow
Sometimes this is a problem with the drain pump filter. It will get clogged with debris which will cause unit to spin slowly. The panel at the front bottom of unit will grant you access to the filter on the pump. Get a bowl or bucket and get ready to catch some water. Good luck
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle to slow...
have you tried the filter if it is blocked it will not empty properly. joe
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22062 will not cycle correctly
Problem fixed. I took apart the bottom of the washer to access the pump, and found that there was underwire from bras stuck in the discharge tube blocking the water from exiting the washer and that was causing the cycle problem. I guess that the washer knew that there was too much water in the tub and kept trying to expel it.
Nov 14, 2008 | Kenmore 22062 Top Load Washer
Sometimes it doesn't spin
might have a small blockadge in the pump if he pump doesnt get the water out in time it wont spin due to the water left in the pump or it could be the carbon brushes which are situated in the motor these are plastic with the carbon inside they are eld on by 2screws if these are lower then 8ml they are too low they need replacing
Nov 17, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSQ9610L Top Load Washer Logo
23 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
